The PowerLine AV 500 Wireless N Mini Starter Kit allows you to extend your existing home network to enjoy high-speed and reliable connectivity throughout your home. By combining both PowerLine and wireless technology, it allows you to extend and create wireless networks, with the latest HomePlug AV and Wireless N standards, where it was not possible before. Using your existing electrical wiring, no additional wires are necessary to extend your network.
This convenient kit contains everything you need to extend your home network to where your wireless signals cannot reach.
Advanced technology built into these devices make them more resistant to electrical interference from other household appliances, so you can fully benefit from a high speed Internet connection. Up to 500 Mbps for faster file sharing, lag free gaming and smooth HD video streaming. Wireless N provides up to 300 Mbps speeds to your wireless-enabled devices.
No need for any IT or networking knowledge. Simply plug one adapter into any power outlet and connect it to your route, and the other adapter to your Internet-enabled device. Fits discreetly into your power outlet and with two network ports you can connect even more devices.
Secure your network from unwanted connections with a simple push of a button. All that is required for a secure set-up is the push of a button on the side of the adapters.
In addition, the adapters in the kit are designed with power-saving features such as the stand-by mode: if data transmission does not occur over a certain period of time, the adapters will automatically go into low-consumption state to save power.
Data transmission over electrical wiring
The D-Link DHP-W311AV PowerLine AV 500 Wireless N Starter Kit, compliant with the HomePlug AV standard, uses your home's existing electrical wiring to create a network or extend your existing network. It turns every power outlet into a potential network connection to access digital media devices, game consoles, print servers, computers, and network storage devices throughout your home. Additionally, Wireless N provides high speed transfers without the need for unsightly network cables. -
Faster wireless speeds and wider operational range
The Wireless N Technology incorporated into this PowerLine product offers increased speed and range beyond standard 802.11g technology. Initial wireless setup can be accomplished quickly, thanks to a convenient setup wizard. WPA and WPA2 encryption keep your network traffic safe and secure. -
Ideal for bandwidth intensive applications
This kit is capable of delivering PowerLine AV 500 data transfer rates of up to 500 Mbps and Wireless N speeds of up to 300 Mbps. This rapid transmission speed makes it ideal for bandwidth-intensive applications, guaranteeing smooth HD video streaming, clear VoIP calls, and lag-free online gaming experiences. In addition, it prioritizes Internet traffic, ensuring that multimedia applications do not experience glitches while web surfing and downloads are in progress. This device provides ample network bandwidth, enabling digital home consumers to tap into existing electrical wiring for high-quality multimedia streaming. -
Convenient setup and secure operation
The DHP-W311AV plugs directly into a power outlet, and does not require any additional cables. Extend your home network by connecting multiple devices to the farthest corners of your home via Ethernet cable or Wireless N. For convenient setup, wired or wireless encryption keys can be quickly configured with the push of a button on top of the device. The adapter implements 128-bit AES data encryption to protect your network from unauthorized access. With hassle-free 'plug and play' installation, the DHP-W311AV is an ideal solution to create a wall-to-wall home network.
- D-Link PowerLine DHP-W311AV - Starter Kit - powerline adapter kit - Wi-Fi - wall-pluggable
- Powerline adapter kit
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV), IEEE 1901
- Data Transfer Rate
- 500 Mbps
- 128-bit encryption, 64-bit encryption, auto-uplink (auto MDI/MDI-X), IPv6 support, Quality of Service (QoS)
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV, IEEE 1901
- Power
- AC 120/230 V (50/60 Hz)
- 9 cm x 6.5 cm x 5 cm
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wireless, wired
- 500 Mbps
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV, IEEE 1901, UL, FCC, RoHS, LVD
- Status Indicators
- Port status, power
- 1 x HomePlug AV , LAN: 1 x 10Base-T/100Base-TX - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 6 Watt
- 9 cm
- 6.5 cm
- 5 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
