D-Link's DGS-1100 Series provide an affordable solution for SOHOs and Small and Medium Businesses as well as enterprise deployment, such as in branch offices and meeting rooms that require simple network management. Most models comes in a compact desktop-sized metal case and features a wide selection of Gigabit port configurations with optional Gigabit fiber uplink ports. There are 4 switches in the series supporting Power-over-Ethernet with 2 of the switches in the offering high-power-budget PoE for businesses looking to power VoIP phones, wireless access points or network cameras.
D-Link power saving performance
Compliant with IEEE802.3az energy efficient Ethernet, the switch consumes less energy by cutting down on power consumption when port utilization is low. By deploying EEE devices, users can cut operating costs and even cut down on necessary cooling equipment, helping small and medium-sized businesses stay within their budgets. -
Easy to deploy
The DGS-1100 Series supports an intuitive D-Link network assistant utility and a web-based management interface. With this utility, users do not need to change the IP address of their PC, and this also makes initial setup of the Smart Switches quick and easy. -
QoS and bandwidth control
The DGS-1100 Series supports Auto Surveillance VLAN (ASV), and Auto Voice VLAN, which are well suited for VoIP and video surveillance deployments. Auto Surveillance VLAN consolidates data and surveillance video transmission through a single DGS-1100 Series switch, thus sparing businesses the expense of dedicated hardware and facilities. ASV also ensures the quality of real-time video for monitoring and control without compromising the transmission of conventional network data. The Auto Voice VLAN technology enhances the VoIP service by automatically placing voice traffic from an IP phone to an assigned VLAN. With higher priority and individual VLAN, these features guarantee the quality and security of VoIP traffic. -
Easy troubleshooting
The DGS-1100 Series feature loopback detection and cable diagnostics to help network administrators find and solve network problems quickly and easily. Loopback detection is used to detect loops created by a specific port and automatically shut down the affected port. The cable diagnostics feature is designed for network administrators to quickly examine the quality of the copper cables, recognize the cable type, and detect cable errors. -
Advanced features
DGS-1100 Series is equipped with advanced security features such as Static MAC, Storm Control, and IGMP Snooping. Static MAC allows users to create a MAC whitelist for specific ports, helping administrators limit network access to authorized devices only. Storm Control monitors broadcast, multicast, or unknown unicast traffic and will start blocking or discarding packets which could flood the network when the defined threshold is exceeded. IGMP Snooping is able to reduce the loading of L3 multicast routers and save bandwidth in network throughput.
- D-Link DGS 1100-18 - switch - 18 ports - Managed - rack-mountable
- Switch - 18 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000 + 2 x SFP
- Performance
- Switching capacity: 36 Gbps , Forwarding performance: 26.79 Mpps
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9216 bytes
- Remote Management Protocol
- HTTP
- Flow control, full duplex capability, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Quality of Service (QoS), Cable Diagnostics Function, bandwidth control, D-Link Green Technology, fanless, LLDP support, DHCP client, Energy Efficient Ethernet
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 28 cm x 18 cm x 4.4 cm
- 1.56 kg
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- 16K entries
- 9216 bytes
- HTTP
- Flash Memory
- 8 MB
- Status Indicators
- Port transmission speed, power, link/activity
- 16 x 1000Base-T RJ-45 , 2 x SFP
- Power Device
- Internal power supply
- Voltage Required
- 14.88 Watt
- MTBF
- 2,671,256 hours
- FCC Class A certified, C-Tick, BSMI, cUL, CB, CCC, RoHS, LVD, VCCI Class A
- 28 cm
- 18 cm
- 4.4 cm
- 1.56 kg
- -5 °C
- 50 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
