D-Link DGE-528T 10 / 100 / 1000Mbps Copper Gigabit PCI Card for PC
Customer rating: 5.0* (Write a review)
Quicklinx: 3N3BWS00 Mfr#: DGE-528T
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: Mac, PC
Type: Network adapter
15 in stock
£9.23 ex VAT
£11.07 inc VAT
The D-Link DGE-528T is a high-performance 10/100/1000Mbps copper Gigabit PCI card for desktop PC. Capable of running at full-duplex Gigabit speed, this card gives your PC 2000Mbps data transmission on your existing Cat. 5 twisted-pair network cable. As an inexpensive alternative solution to fiber-optic, the card allows you to instantly upgrade to Gigabit without requiring you to install new, expensive fiber cables. The card supports 10/100/1000Mbps network speed auto-sensing and full/half duplex auto-negotiation.
The card provides on-board screening of VLANs Tagged Ethernet frames, allowing your PC to be configured with VLAN-supported switch. Your PC can be part of a VLAN network, where domains are segmented up to enhance performance and security.
Wake-On-LAN (WOL) is an Advanced Configuration Power Interface (ACPI) function allowing a powered OFF computer to be powered ON from a remote station. This function allows the administrator to send wake-up signals to a computer. The WOL function provides a great utility for power management of the PC and allows users to initiate action at irregular times and from distant locations.
The card's embedded flow control and independent FIFO provide a means to protect against possible data loss during transmission on the network. When connected to a Gigabit switch supporting flow control, the card receives signals from the switch regarding buffer overrun during peak usage periods. The card then delays transmission until the switch is ready again to accept new data.
Using a single chip solution, this card is very small in size and consumes very little power of your computer system.
  • High-performance gigabit speed
    Capable of running at full-duplex gigabit speed, this card gives your PC 2000Mbps data transmission on your existing Cat. 5 twisted-pair network cable. As an inexpensive alternative solution to fiber-optic, the card allows you to instantly upgrade to Gigabit without requiring you to install new, expensive fiber cables. The card supports 10/100/1000Mbps network speed auto-sensing and full/half duplex auto-negotiation.
  • VLAN to improve performance and security
    The card provides on-board screening of VLANs Tagged Ethernet frames, allowing your PC to be configured with a VLAN-supported switch. Your PC can be part of a VLAN network, where domains are segmented up to enhance performance and security.
  • Wake-On-LAN for power management
  • Flow control to minimize packet loss
    The card's embedded flow control and independent FIFO provide a means to protect against possible data loss during transmission on the network. When connected to a gigabit switch supporting flow control, the card receives signals from the switch regarding buffer overrun during peak usage periods. The card then delays transmission until the switch is ready again to accept new data.
  • Small form factor, lower power requirement
D-Link DGE-528T - network adapter
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI
PCI Specification Revision
PCI 2.2
Ports
Gigabit Ethernet
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x
Microsoft Windows NT 4.0, Novell NetWare 5.x, Apple MacOS X, Novell NetWare 6.x, Linux 2.2.x, Linux 2.4.x, Microsoft Windows 98/ME/2000/XP
Microsoft Certification
Works with Windows Vista
Network adapter
PCI
PCI 2.2
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
Port transmission speed, port duplex mode, link/activity
Flow control, full duplex capability, auto-sensing per device, auto-negotiation, VLAN support, wake on LAN (WOL), auto-uplink (auto MDI/MDI-X)
1 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI - low-profile
Low-profile bracket
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Plug and Play, ACPI 2.0, FCC Class B certified, VCCI Class B ITE
Additional Requirements
PCI slot
50 °C
10 - 90%
3N3B C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.27
3N3B C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.18
3N3B C2G 2m Cat6a Shielded Patch - Blue In Stock £7.49
Customer reviews
Write a review for the D-Link DGE-528T 10 / 100 / 1000Mbps Copper Gigabit PCI Card for PC here!
Superb card
Reviewed by Anonymous Review Posted 25/01/2007
I bought 3 of these and their sexy looking 5 port gigabit hub last year, and have to say the performance is excellent in both windows and linux.
You have to install the driver yourself under windows, but any recent kernel in Linux should pick it up no problem at all.
I'm almost tempted to buy more, but then I'd need to buy another switch!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Seems like good value to me...
Reviewed by Rob Whalley. Review Posted 30/03/2007
Have just purchased one of these cards for our office to suit a Dell Dimension C521 with Vista Ultimate. It's a good system but didn't have an option for gigabit network interface card. Also, the C521 requires a low profile card - not an easy thing to find! Based on this page: http://www.edlug.org.uk/archive/Jan2007/msg00155.html I decided to take a chance and the NIC does indeed have a separate low profile plate in the box. One quick change later (just two screws) and I had the card installed. Vista got the drivers off the CD with no problems too! Great stuff.
  • Overall 5*
  • Ease of use 5*
Fine with Windows 2003 and Linux
Reviewed by Anonymous Review Posted 22/09/2007
I've had them working fine with both Windows 2003 and Linux (not tried XP yet.) If it's any help to others, you can use the r8169 module for Linux (on Debian Etch, anyway.) The supplied drivers (r1000) compiled for me after changing the start of line 387 in the source from MODULE_PARM to MODULE_PARM_DESC - found after a lot of looking around the Web.
  • Overall 5*
  • Ease of use 5*
Read all 5 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: Mac
Compatibility: PC
Brand: D-Link
Price Range Ex VAT: 0 - 50
