The D-Link DES-1018P/DES-1018MP 18-Port Fast Ethernet PoE Switches with 2 Gigabit Uplink Ports enables users to easily connect and supply power to PoE-capable devices such as wireless access points (APs), network cameras and IP phones. They can also connect other Ethernet devices like computers, printers and network attached storage (NAS) to fit into any type of network application.
Power your devices
Supports IEEE 802.3af Power-over-Ethernet (PoE) to power on your PoE-capable network devices via Ethernet cables without using power adapters. -
Reliability PoE connections
Enhanced surge protection on all PoE ports protects the switch when feeding power to outdoor PoE capable devices. -
Flexible connectivity
All downlink ports support 10/100M speeds, and two Gigabit uplink ports provide redundant, wired speed connection for reliable networking.
- D-Link DES 1018P 18-Port Fast Ethernet PoE Switch with 2 Gigabit Uplink Ports - switch - 16 ports - unmanaged
- Switch - 16 ports - unmanaged
- Enclosure Type
- 1U
- Ports
- 8 x 10/100 (PoE) + 8 x 10/100 + 2 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 80 W
- Performance
- Switching capacity: 7.2 Gbps , Forwarding performance (64-byte packet size): 5.36 Mpps
- MAC Address Table Size
- 8K entries
- Flow control, power over Ethernet (PoE), auto-uplink (auto MDI/MDI-X), store and forward, 384KB packet buffer, Energy Efficient Ethernet
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 28 cm x 21 cm x 4.4 cm
- 1.78 kg
- Enclosure Type
- Desktop 1U
- Ports
- PoE
- PoE Budget
- 80 W
- Performance
- 8K entries
- Status Indicators
- Port transmission speed, power, link/activity
- 8 x 100Base-TX RJ-45 PoE - 15.4 W , 8 x 100Base-TX RJ-45 , 2 x 1000Base-X RJ-45 , 2 x 1000Base-T SFP
- Power Device
- Internal power supply
- Voltage Required
- 102.6 Watt
- MTBF
- 395,864 hours
- FCC Class A certified, VCCI, C-Tick, BSMI, cUL, CB, CCC, RoHS, LVD
- 28 cm
- 21 cm
- 4.4 cm
- 1.78 kg
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
