D-Link DEM-311GT 1-Port Mini GBIC SX Multi Mode Fiber Transceiver
Quicklinx: 2NG0WS00 Mfr#: DEM-311GT
Type: Transceiver
Hurry, only 2 left in stock!
£39.85 ex VAT
£47.82 inc VAT
This transceiver uses the industry-standard Small form Pluggable (SFP) package. It slides into the mini-GBIC slot of the Gigabit device. Like all D-Link mini-GBIC transceivers, it is hot-swappable: you can remove or replace the transceiver with the system powered on, which allows modules to be added or swapped without interrupting the network.
D-Link DEM 311GT - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
GigE
Max Transfer Distance
550 m
D-Link Data Center 10, DES-3028, 3052, DWS-3024, DXS-1100-16, 1210-16, 3400-24, 3600-16; DES 12XX, 30XX; DGS 3100, 32XX, 3630; L2+ Gigabit Wireless Switch; Web Smart DES-1228, 1252, DGS-1216, 1224, 1248, DXS-1210-12; xStack DES-3526, 3528, 3552, 3828, 3852, DGS-3426, 3427, 3450, 3612, 3627, 3650
Plug-in module
Wired
Cabling Type
1000Base-SX
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
1 x Ethernet 1000Base-SX - LC multi-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
D-Link Data Center 10GbE Top-of-Rack Switch DXS-3600, DES-3028P, DES-3052P, DWS-3024L, DXS-1100-16SC, DXS-1210-16TC, DXS-3400-24SC, DXS-3400-24TC, DXS-3600-16S , D-Link DES 1210, 1226G, 3010G, 3028, 3052, 3250TG, 3350SR, 3526, 3550 , D-Link DGS 1024T, 1216T, 1224T, 1248T, 3100-24, 3100-24P, 3100-24TG, 3100-48, 3100-48P, 3200-10, 3200-16, 3224TGR, 3312SR, 3324SR, 3324SRi, 3630-28SC, 3630-28TC, 3630-52TC , D-Link L2+ Gigabit Wireless Switch DWS-3024 , D-Link Web Smart DES-1228, DES-1252, DGS-1216T, DGS-1224T, DGS-1248T, DXS-1210-12TC , D-Link xStack DES-3526, DES-3528, DES-3528P, DES-3552, DES-3828, DES-3828DC, DES-3828P, DES-3852, DGS-3426, DGS-3426P, DGS-3427, DGS-3450, DGS-3612G, DGS-3627, DGS-3627G, DGS-3650, DXS-3326GSR, DXS-3350SR
Type: Transceiver
Brand: D-Link
Price Range Ex VAT: 0 - 50
