D-Link DCS-960L HD 180 Degree Wi-Fi Panoramic Camera
Quicklinx: CV07WS00 Mfr#: DCS-960L
  • microSDHC Card
  • microSD Card
£108.49 ex VAT
£130.18 inc VAT
The DCS-960L HD 180° Panoramic Camera is a revolutionary camera offering a horizon-wide view that easily captures your entire room, wall-to-wall, in high-quality 720p.
  • Unique de-warping technology
    Maximizes the video quality with less distortion - letting you see more of your home at a glance.
  • Home security in high definition
    Crisp 720p HD video gives you a clear view of what's going on at home. See more of your favorite faces and places - it's home security with an eye for detail.
  • Round-the-clock peace of mind
    Peace of mind shouldn't end when the sun goes down. With 16 feet night vision, you'll never miss a thing.
  • Easy to set up, even easier to use
    Get your Wi-Fi camera set up in minutes, and place it just about anywhere in your home.
D-Link DCS 960L HD 180-Degree Wi-Fi Camera - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in microphone
9.6 cm x 9.6 cm x 13.8 cm
141 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
720p
Optical Sensor Type
CMOS - 1/2.7" - 1 MP
Minimum Illumination
0 lux - IR
Focal Length Control
Fixed focal
Focal Length
1.72 mm
Lens Iris
F/2.0
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Voltage
DC 5 V
Date/time stamp, sharpness control, progressive scanning, resizing an image, saturation control, brightness control, contrast control, USB powered, Motion Detection Technology, light sensor, infrared cut filter, Sound Detection Sensor, hue control, Wi-Fi Protected Setup (WPS), reset button, Text Caption Overlay, password protection
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wireless
9.6 cm
9.6 cm
13.8 cm
141 g
Camera
Colour - Day&Night - fixed
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Motion Detection
Video Modes
720p
Digital Zoom
8
0 lux - IR
Infrared LEDs
2
Infrared Distance
4.88 m
Video Capture
1280 x 720 @ 30 fps , 800 x 600 @ 30 fps , 720 x 480 @ 30 fps , 640 x 480 @ 30 fps , 320 x 240 @ 30 fps
Supported Image Formats
JPEG
Image Sensor
1 MP CMOS 1/2.7"
Lens Construction
Fixed focal
Focal Length
1.72 mm
Lens Iris
F/2.0
Horizontal Field of View (degree)
180
Vertical Field of View (degree)
120
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, Bonjour, RTCP, PPPoE
Ports
USB (power only) - Micro-USB Type B
Supported Memory Cards
microSD Card, microSDHC Card
FCC Class B certified, ICES, LVD
Power Requirements
DC 5 V - 1.2 A
Power adapter - external (50/60 Hz)
Relative Humidity (operating)
Type: Home security system
Brand: D-Link
Price Range Ex VAT: 100 - 150
