D-Link DCS-936L HD Wi-Fi Camera
Quicklinx: CV09WS00 Mfr#: DCS-936L
  • microSD Card
13 in stock
£61.52 ex VAT
£73.82 inc VAT
Enjoy home security in high definition. Crisp HD video gives you a clear view of what's going on at home. See more of your favorite faces and places - it's home security with an eye for detail.
  • Responsive recording
    Your camera begins recording automatically to a memory card when it senses changes in your home.
  • Easy to set up
    Quickly get your DCS-936L set, and place it just about anywhere in your home. Easily add cameras to cover different spaces.
D-Link DCS 936L HD Wi-Fi Camera - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in microphone
6.5 cm x 4.8 cm x 8.05 cm
141 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Frame Rate (max)
30 frames per second
Optical Sensor Type
CMOS - 1/4" - 1 MP
Minimum Illumination
0 lux - IR
Focal Length
2.45 mm
Lens Iris
F/2.4
Voltage
DC 5 V
Motion sensor, sharpness control, saturation control, brightness control, contrast control, infrared cut filter, hue control, Wi-Fi Protected Setup (WPS), text stamp, password protection, sound sensor
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 85% (non-condensing) relative humidity
Audio Support
Wireless
6.5 cm
4.8 cm
8.05 cm
141 g
Camera
Colour - Day&Night - fixed
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Digital Zoom
4
0 lux - IR
Infrared LEDs
Infrared Distance
4.88 m
Video Capture
1280 x 720 @ 30 fps , 640 x 352 @ 30 fps , 320 x 176 @ 30 fps
Supported Image Formats
JPEG
Image Sensor
1 MP CMOS 1/4"
Lens Construction
Focal Length
2.45 mm
Lens Iris
F/2.4
Horizontal Field of View (degree)
100
Vertical Field of View (degree)
54
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, UPnP, IPv4, RTCP, PPPoE
Supported Memory Cards
microSD Card, microSDXC Card
FCC Class B certified, C-Tick, ICES, LVD
Power Requirements
DC 5 V - 1.2 A
Power adapter - external (50/60 Hz)
Software Included
Drivers & Utilities, mydlink Lite
Relative Humidity (operating)
Brand: D-Link
Price Range Ex VAT: 50 - 100
