mydlink™ Home app-enabled.
Use the free mydlink™ Home app to view what your Monitor HD sees, using your tablet or smartphone to control it wherever you are in the world.
Wireless connectivity.
Connect the Monitor HD to your Wireless home network, easily and conveniently, using one-button setup.
Motion detection with night vision.
Never miss a thing with the ability to be notified when motion is detected, and night vision ensures clear images even in low-light conditions, so you can always see what the Monitor HD sees.
HD Clarity
See all the details with high definition 720p colour images with sound.
Easy to Setup
Simply press a button to securely connect to your home Wi-Fi network with Wi-Fi Protected Setup. No additional control hub needed.
High Definition
Monitor your home in crystal clear HD 720p - See everything in detail, even when zoomed in.
See in the Dark
Built-in night vision function allows you to see up to 5 metres even in complete darkness.
Motion & Sound Detection
Alerts you with push notification whenever motion or sound is detected.
View From Anywhere
View securely over the Internet through your smartphone or tablet. Works with iOS and Android smartphone and tablet* through the free mydlink™ Home app.
* mydlink™ Home app is available for iPod, iPhone and iPad devices using iOS version 6.0 or later, and Android devices using Android version 4.0 or later.
Monitor everything
This high-definition camera delivers high-quality video for remote viewing on the tablet or smartphone you already own. -
Mydlink Home app-enabled
Use the free mydlink Home app to view what your Monitor HD sees, using your tablet or smartphone to control it wherever you are in the world. -
Connect the Monitor HD to your Wireless home network, easily and conveniently, using one-button setup. -
Never miss a thing with the ability to be notified when motion is detected, and night vision ensures clear images even in low-light conditions, so you can always see what the Monitor HD sees. -
HD clarity
See all the details with high definition 720p color images with sound. -
Easy to setup
Simply press a button to securely connect to your home Wi-Fi network with Wi-Fi protected setup. No additional control hub needed. -
High definition
Monitor your home in crystal clear HD 720p. See everything in detail, even when zoomed in. -
See in the dark
Built-in night vision function allows you to see up to 5 meters even in complete darkness. -
Motion and sound detection
- mydlink Home Monitor HD - network surveillance camera
- Network surveillance camera - fixed
- Audio
- Yes: built-in microphone
- 5.8 cm x 8.45 cm x 12.49 cm
- 160 g
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1280 x 720
- Optical Sensor Type
- CMOS - 1/4"
- Minimum Illumination
- 0 lux - IR - F2.4
- Focal Length
- 2.38 mm
- Focus Adjustment
- (min distance 434 mm)
- Lens Iris
- F/2.4
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Voltage
- DC 5 V
- Motion sensor, date/time stamp, sharpness control, progressive scanning, saturation control, brightness control, contrast control, infrared cut filter, hue control, Wi-Fi Protected Setup (WPS), text stamp
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Wireless
- 5.8 cm
- 8.45 cm
- 12.49 cm
- 160 g
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 720
- Digital Zoom
- 4
- Exposure Range
- 1/7.5 sec - 1/24000 sec
- 0 lux - IR - F2.4
- Infrared Distance
- 5 m
- Digital Video Capture Resolution
- 1280 x 720, 720 x 480, 640 x 480, 320 x 240, 800 x 600
- Supported Image Formats
- JPEG
Image Sensor
- CMOS 1/4"
Lens Construction
- Focal Length
- 2.38 mm
- Lens Iris
- F/2.4
- Min Focus Distance
- 434 mm
- Horizontal Field of View (degree)
- 78.44
- Vertical Field of View (degree)
- 47.9
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RNCP, RTSP, RTP, HTTPS, UPnP, IPv4, Bonjour, PPPoE
- FCC Class B certified
- Power Requirements
- DC 5 V
- Power Device
- 3.5 Watt
- OS Required
- Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
