D-Link DCS-935L mydlink Home Monitor HD
SALE PRICE - WAS £89.98!
Quicklinx: 9T7WWS00 Mfr#: DCS-935L
mydlink™ Home app-enabled.
Use the free mydlink™ Home app to view what your Monitor HD sees, using your tablet or smartphone to control it wherever you are in the world.
Wireless connectivity.
Connect the Monitor HD to your Wireless home network, easily and conveniently, using one-button setup.
Motion detection with night vision.
Never miss a thing with the ability to be notified when motion is detected, and night vision ensures clear images even in low-light conditions, so you can always see what the Monitor HD sees.
HD Clarity
See all the details with high definition 720p colour images with sound.
Easy to Setup
Simply press a button to securely connect to your home Wi-Fi network with Wi-Fi Protected Setup. No additional control hub needed.
High Definition
Monitor your home in crystal clear HD 720p - See everything in detail, even when zoomed in.
See in the Dark
Built-in night vision function allows you to see up to 5 metres even in complete darkness.
Motion & Sound Detection
Alerts you with push notification whenever motion or sound is detected.
View From Anywhere
View securely over the Internet through your smartphone or tablet. Works with iOS and Android smartphone and tablet* through the free mydlink™ Home app.
* mydlink™ Home app is available for iPod, iPhone and iPad devices using iOS version 6.0 or later, and Android devices using Android version 4.0 or later.
  • Monitor everything
    This high-definition camera delivers high-quality video for remote viewing on the tablet or smartphone you already own.
  • Mydlink Home app-enabled
    Use the free mydlink Home app to view what your Monitor HD sees, using your tablet or smartphone to control it wherever you are in the world.
  • Wireless connectivity
  • Motion detection with night vision
  • HD clarity
    See all the details with high definition 720p color images with sound.
  • Easy to setup
    Simply press a button to securely connect to your home Wi-Fi network with Wi-Fi protected setup. No additional control hub needed.
  • High definition
    Monitor your home in crystal clear HD 720p. See everything in detail, even when zoomed in.
  • See in the dark
    Built-in night vision function allows you to see up to 5 meters even in complete darkness.
  • Motion and sound detection
mydlink Home Monitor HD - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in microphone
5.8 cm x 8.45 cm x 12.49 cm
160 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
0 lux - IR - F2.4
Focal Length
2.38 mm
Focus Adjustment
(min distance 434 mm)
Lens Iris
F/2.4
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Voltage
DC 5 V
Motion sensor, date/time stamp, sharpness control, progressive scanning, saturation control, brightness control, contrast control, infrared cut filter, hue control, Wi-Fi Protected Setup (WPS), text stamp
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wireless
5.8 cm
8.45 cm
12.49 cm
160 g
Camera
Colour - Day&Night - fixed
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Digital Zoom
4
Exposure Range
1/7.5 sec - 1/24000 sec
0 lux - IR - F2.4
Infrared Distance
5 m
Digital Video Capture Resolution
1280 x 720, 720 x 480, 640 x 480, 320 x 240, 800 x 600
Supported Image Formats
JPEG
Image Sensor
CMOS 1/4"
Lens Construction
Focal Length
2.38 mm
Lens Iris
F/2.4
Min Focus Distance
434 mm
Horizontal Field of View (degree)
78.44
Vertical Field of View (degree)
47.9
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RNCP, RTSP, RTP, HTTPS, UPnP, IPv4, Bonjour, PPPoE
FCC Class B certified
Power Requirements
DC 5 V
3.5 Watt
Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8
Relative Humidity (operating)
