D-Link DCS-932L-TWIN/B Wi-Fi Day/Night Camera Twin Pack
Quicklinx: 9T86WS00 Mfr#: DCS-932L-TWIN/B
The DCS-932L, Wireless N Day & Night Home Network Camera, is a versatile monitoring solution for your home or small office, whether by day or night courtesy of the built-in Infrared LEDs. With mydlink included, this camera provides the simplest way to access and manage your camera, via your computer or via the free mydlink app on your iPhone, Android or tablet. No technical knowledge required!
Connecting a camera to your network and accessing it has traditionally required complex configuration. Thanks to mydlink home monitoring is now made simple.
mydlink makes it easy to access your camera from wherever you are, whenever it's convenient for you- for free. A step-by-step guide has your camera up and running in a matter of minutes. Then via a simple website you can set up a mydlink account allowing you to view and manage your camera from any Internet connected computer. If you have more than one camera, you can add it to your existing mydlink account and watch all your cameras from a single location.
Accessing your cameras on the go is easy too. Just download the free mydlink app for your iPhone or Android and you can quickly and easily view your camera feed from anywhere with a wireless or 3G connection.
The camera comes with built-in infrared LEDs that allow for continuous monitoring even in complete darkness. The 5-meter illumination distance makes it suitable for monitoring what matters to you most; your baby, sleeping in the nursery, or your office 24/7.
This camera includes additional features such as motion detection and email alerts, via the User Interface. This makes the camera a truly comprehensive home monitoring system for those that want to do more.
You can easily set up a detection area (i.e. a window, or your garage door) on the camera's User Interface, so that emails will be sent to you to notify you of any motion detected.
You can also view up to 32 cameras from a Windows computer using the included free D-ViewCam software (DCS-100). D-ViewCam also has a robust set of features including centralized alert management and video/audio recording.
The DCS-932L camera includes Wireless N technology for wider coverage around your home. Wireless N also allows you to stream high-quality video to remote sites over the Internet. A Site Survey feature also allows you to view and connect to nearby wireless networks with ease. The DCS-932L also includes a standard Ethernet port for connections to traditional wired networks.
  • Simple to use
    The DCS-932L is a stand-alone system with a built-in CPU, requiring no special hardware or software such as PC frame grabber cards. The DCS-932L supports both ActiveX mode for Internet Explorer and Java mode for other browsers such as Firefox" and Safari.
  • Supports a variety of platforms
    Supporting TCP/IP networking, HTTP, and other Internet related protocols. The DCS-932L can also be integrated easily into other Internet/Intranet applications because of its standards-based features.
  • 802.11 b/g/n wireless or Ethernet/fast Ethernet support
    The DCS-932L offers wireless 802.11 b/g/n and Ethernet/Fast Ethernet connectivity, making the DCS-932L easy to integrate into your existing network environment. The DCS-932L works with a 10Mbps Ethernet based network or 100Mbps Fast Ethernet based network for traditional wired environments, and works with 802.11 b/g/n routers or access points for added flexibility. The Site Survey feature also allows you to view and connect to any available wireless networks.
  • Web configuration
    Using a standard Web browser, administrators can configure and manage the Network Camera directly from its own Web page via Intranet or Internet. This means you can access your DCS-932L anytime, anywhere in the world.
  • Broad range of applications
    With today's high-speed Internet services, the Network Camera can provide the ideal solution for delivering live video images over the Intranet and Internet for remote monitoring. The Network Camera allows remote access using a Web browser for live image viewing, and allows the administrator to manage and control the Network Camera anytime, anywhere in the world. Many applications exist, including industrial and public monitoring of homes, offices, banks, hospitals, child-care centers, and amusement parks.
  • Remote monitoring utility
    The D-ViewCam application adds enhanced features and functionality for the Network Camera and allows administrators to configure and access the Network Camera from a remote site via Intranet or Internet. Other features include image monitoring, recording images to a hard drive, viewing up to 32 cameras on one screen, and taking snapshots.
D-Link DCS 932L - network surveillance camera
Network surveillance camera - fixed
Packaged Quantity
2 (specifications are for single item)
Audio
Yes: built-in microphone
6 cm x 3.215 cm x 9.6 cm
57.8 g
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
640 x 480
Frame Rate (max)
20 frames per second
Motion Detection
Optical Sensor Type
CMOS - 1/5"
Minimum Illumination
0 lux - infrared LEDs on
Focal Length Control
Fixed focal
Focal Length
3.15 mm
Focus Adjustment
(min distance 500 mm)
Lens Iris
F/2.8
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 5 V
Date/time stamp, progressive scanning, saturation control, contrast control, Motion Detection Technology, light sensor, infrared cut filter, Wi-Fi Protected Setup (WPS), text stamp, password protection
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Packaged Quantity
Audio Support
Wired, wireless
6 cm
3.215 cm
9.6 cm
57.8 g
United Kingdom
Camera
Colour - Day&Night - fixed
Digital Video Format
MJPEG
Max Digital Video Resolution
640 x 480
Motion Detection
Digital Zoom
4
Exposure Range
1/3.75 sec - 1/14640 sec
Infrared LEDs
Infrared Distance
5 m
Video Capture
160 x 112 @ 30 fps , 320 x 240 @ 30 fps , 640 x 480 @ 20 fps
Supported Image Formats
JPEG
Image Sensor
CMOS 1/5"
Lens Construction
Fixed focal
Focal Length
3.15 mm
Lens Iris
F/2.8
Min Focus Distance
500 mm
Horizontal Field of View (degree)
45.3
Vertical Field of View (degree)
34.5
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, UPnP, IPv4, PPPoE, LLTD
Stand
FCC Class B certified, C-Tick, IC
Power Requirements
DC 5 V - 1 A
Power adapter - external 2.84 Watt
Software Included
D-ViewCam
Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8
Relative Humidity (operating)
9T86 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
