The DCS-932L, Wireless N Day & Night Home Network Camera, is a versatile monitoring solution for your home or small office, whether by day or night courtesy of the built-in Infrared LEDs. With mydlink included, this camera provides the simplest way to access and manage your camera, via your computer or via the free mydlink app on your iPhone, Android or tablet. No technical knowledge required!
Connecting a camera to your network and accessing it has traditionally required complex configuration. Thanks to mydlink home monitoring is now made simple.
mydlink makes it easy to access your camera from wherever you are, whenever it's convenient for you- for free. A step-by-step guide has your camera up and running in a matter of minutes. Then via a simple website you can set up a mydlink account allowing you to view and manage your camera from any Internet connected computer. If you have more than one camera, you can add it to your existing mydlink account and watch all your cameras from a single location.
Accessing your cameras on the go is easy too. Just download the free mydlink app for your iPhone or Android and you can quickly and easily view your camera feed from anywhere with a wireless or 3G connection.
The camera comes with built-in infrared LEDs that allow for continuous monitoring even in complete darkness. The 5-meter illumination distance makes it suitable for monitoring what matters to you most; your baby, sleeping in the nursery, or your office 24/7.
This camera includes additional features such as motion detection and email alerts, via the User Interface. This makes the camera a truly comprehensive home monitoring system for those that want to do more.
You can easily set up a detection area (i.e. a window, or your garage door) on the camera's User Interface, so that emails will be sent to you to notify you of any motion detected.
You can also view up to 32 cameras from a Windows computer using the included free D-ViewCam software (DCS-100). D-ViewCam also has a robust set of features including centralized alert management and video/audio recording.
The DCS-932L camera includes Wireless N technology for wider coverage around your home. Wireless N also allows you to stream high-quality video to remote sites over the Internet. A Site Survey feature also allows you to view and connect to nearby wireless networks with ease. The DCS-932L also includes a standard Ethernet port for connections to traditional wired networks.
Watch The Home Monitoring Cameras Unboxing Video!
- D-Link DCS 932L mydlink-enabled Wireless N IR Home Network Camera - network surveillance camera
- Network surveillance camera - fixed
- Audio
- Yes: built-in microphone
- 6 cm x 2.7 cm x 9.6 cm
- 77 g
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 640 x 480
- Optical Sensor Type
- CMOS - 1/5" - 0.3 MP
- Minimum Illumination
- 1 lux - colour - F2.8
- Lens Iris
- F/2.8
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Cables Included
- 1 - network cable - external
- Voltage
- DC 5 V
- Date/time stamp, e-mail alerts, image flip, image mirror, automatic electronic shutter, upgradable firmware, Wi-Fi Protected Setup (WPS), auto gain control, auto white balance
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Wired, wireless
- 6 cm
- 2.7 cm
- 9.6 cm
- 77 g
- Localisation
- United Kingdom
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- MJPEG
- Max Digital Video Resolution
- 640 x 480
- Digital Zoom
- 4
- Infrared LEDs
- Video Capture
- 160 x 120 @ 30 fps , 320 x 240 @ 30 fps , 640 x 480 @ 20 fps
- Supported Image Formats
- JPEG
- RAM
- 32 MB
- Flash Memory
- 4 MB
Image Sensor
- 0.3 MP CMOS 1/5"
Lens Construction
- Lens Iris
- F/2.8
- Horizontal Field of View (degree)
- 45.3
- Vertical Field of View (degree)
- 34.5
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, UPnP, IPv4, PPPoE
- 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
- Included Accessories
- Stand
- Cables Included
- 1 x network cable - external
- FCC Class B certified, C-Tick, IC
- Power Requirements
- DC 5 V - 1.2 A
- Power Device
- Power adapter - external AC 120/230 V (50/60 Hz) 2 Watt
- Software Included
- D-ViewCam
- OS Required
- Microsoft Windows Vista / XP / 7
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
C2G 2m 3.5mm M/M Stereo Audio Cable | In Stock | £4.29 |
C2G 3m 3.5mm M/M Stereo Audio Cable | In Stock | £4.26 |
C2G 5m Velocity™ 3.5mm M/M Stereo Audio Cable | In Stock | £6.35 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.13 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £11.02 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £6.84 |
