D-Link DCS 7110 HD Outdoor Day & Night Network Camera
Quicklinx: 7GR7WS00 Mfr#: DCS-7110/B
The D-Link DCS-7110 is an all-in-one, outdoor network camera equipped with industry-leading high definition (Full HD) megapixel resolution and H.264 compression. The DCS-7110 connects to a network to provide high-quality live video over the Internet, capable of capturing video in both day and night environments thanks to its built-in IR LEDs and IR-cut removable (ICR) filter. This feature allows the camera to capture crisp color images during the daytime and detailed grayscale images at night or in or low-light conditions.
  • Multiple video streams
    The DCS-7110 supports simultaneous streaming of H.264, MPEG-4, and MJPEG video to provide both high-quality and bandwidth-efficient compression formats. H.264 produces a small file size, making it useful for extended recording in high detail or for use in low-bandwidth networks. MJPEG delivers excellent file integrity, ideal for situations which require better image quality. Additionally, the DCS-7110 supports multicast H.264 streaming, allowing users to view the camera feed by subscribing to a multicast IP address on the network.
  • Flexible connectivity
    The DCS-7110 includes input and output ports for connectivity to external devices such as IR sensors, switches, and alarm relays. The DCS-7110 also incorporates Power over Ethernet (PoE), allowing it to be easily installed in a variety of locations without the need for supplemental power cabling.
  • Weatherproof and tamper proof
    Designed to be mounted outdoors, the DCS-7110 includes an IP66 certified enclosure which protects against the elements. Anti-tamper features make this camera suitable for tamper-prone locations such as transportation hubs, schools, or correctional facilities. The electronic tamper detection system can sense when the camera has been redirected, de-focused, blocked, or spray-painted, and respond promptly with a visible or audible alarm.
  • Centralized management with D-ViewCam
    The included D-Link D-ViewCam IP camera surveillance software is a comprehensive surveillance system designed to centrally manage multiple IP cameras. Supporting up to 32 IP cameras, D-ViewCam is compatible with all current D-Link IP cameras, Video Servers and offers digital monitoring and recording capabilities of video, audio, and events for various security applications. This software provides users with a wide array of features for added convenience, including video recording, playback, video live view, offering users powerful surveillance software that's easy to use.
D-Link DCS 7110 HD Outdoor Day & Night Network Camera - network surveillance camera
Network surveillance camera - fixed - outdoor - tamper-proof / weatherproof
5.1 cm x 6.8 cm x 4.2 cm
808 g
Wired
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Optical Sensor Type
CMOS - 1/2.7" - 2 MP
Minimum Illumination
0.12 lux - colour - F1.5 , 0 lux - IR - F1.5
Focal Length
4 mm
Lens Iris
F/1.5 - fixed iris
Voltage
DC 12 V / AC 24 V / PoE
Motion sensor, date/time stamp, IR filter, Power over Ethernet, Open Network Video Interface Forum (ONVIF), built-in IR illuminator, Privacy Mask Function, tamper-detection
Environmental Parameters (operating)
-20 °C - 50 °C
Wired
5.1 cm
6.8 cm
4.2 cm
808 g
United Kingdom
Camera
Colour - Day&Night - fixed - outdoor - tamper-proof / weatherproof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Exposure Range
1/5 sec - 1/32000 sec
Infrared Distance
15 m
Video Capture
1920 x 1080 @ 15 fps , 1280 x 800 @ 30 fps , 1280 x 720 @ 30 fps , 640 x 480 @ 30 fps , 320 x 240 @ 30 fps
Supported Image Formats
JPEG
Image Sensor
2 MP CMOS 1/2.7"
Lens Construction
Focal Length
4 mm
Lens Iris
F/1.5 fixed iris
Horizontal Field of View (degree)
77.4
Vertical Field of View (degree)
45.1
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, SMTP, TCP/IP, UDP/IP, ICMP, SNMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, PPPoE, IGMP, Samba, QOS, CoS
1 x network / power - Ethernet 10Base-T/100Base-TX , 1 x camera - RS-485
FCC Class A certified, C-Tick, ICES-003, IEC 60529 IP66, IP66
Power Requirements
Software Included
Drivers & Utilities, D-ViewCam
-20 °C
50 °C
7GR7 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
