The D-Link DCS-7110 is an all-in-one, outdoor network camera equipped with industry-leading high definition (Full HD) megapixel resolution and H.264 compression. The DCS-7110 connects to a network to provide high-quality live video over the Internet, capable of capturing video in both day and night environments thanks to its built-in IR LEDs and IR-cut removable (ICR) filter. This feature allows the camera to capture crisp color images during the daytime and detailed grayscale images at night or in or low-light conditions.
Multiple video streams
The DCS-7110 supports simultaneous streaming of H.264, MPEG-4, and MJPEG video to provide both high-quality and bandwidth-efficient compression formats. H.264 produces a small file size, making it useful for extended recording in high detail or for use in low-bandwidth networks. MJPEG delivers excellent file integrity, ideal for situations which require better image quality. Additionally, the DCS-7110 supports multicast H.264 streaming, allowing users to view the camera feed by subscribing to a multicast IP address on the network. -
Flexible connectivity
The DCS-7110 includes input and output ports for connectivity to external devices such as IR sensors, switches, and alarm relays. The DCS-7110 also incorporates Power over Ethernet (PoE), allowing it to be easily installed in a variety of locations without the need for supplemental power cabling. -
Weatherproof and tamper proof
Designed to be mounted outdoors, the DCS-7110 includes an IP66 certified enclosure which protects against the elements. Anti-tamper features make this camera suitable for tamper-prone locations such as transportation hubs, schools, or correctional facilities. The electronic tamper detection system can sense when the camera has been redirected, de-focused, blocked, or spray-painted, and respond promptly with a visible or audible alarm. -
Centralized management with D-ViewCam
The included D-Link D-ViewCam IP camera surveillance software is a comprehensive surveillance system designed to centrally manage multiple IP cameras. Supporting up to 32 IP cameras, D-ViewCam is compatible with all current D-Link IP cameras, Video Servers and offers digital monitoring and recording capabilities of video, audio, and events for various security applications. This software provides users with a wide array of features for added convenience, including video recording, playback, video live view, offering users powerful surveillance software that's easy to use.
- D-Link DCS 7110 HD Outdoor Day & Night Network Camera - network surveillance camera
- Network surveillance camera - fixed - outdoor - tamper-proof / weatherproof
- 5.1 cm x 6.8 cm x 4.2 cm
- 808 g
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Optical Sensor Type
- CMOS - 1/2.7" - 2 MP
- Minimum Illumination
- 0.12 lux - colour - F1.5 , 0 lux - IR - F1.5
- Focal Length
- 4 mm
- Lens Iris
- F/1.5 - fixed iris
- Voltage
- DC 12 V / AC 24 V / PoE
- Motion sensor, date/time stamp, IR filter, Power over Ethernet, Open Network Video Interface Forum (ONVIF), built-in IR illuminator, Privacy Mask Function, tamper-detection
- Environmental Parameters (operating)
- -20 °C - 50 °C
- Wired
- 5.1 cm
- 6.8 cm
- 4.2 cm
- 808 g
- Localisation
- United Kingdom
Camera
- Colour - Day&Night - fixed - outdoor - tamper-proof / weatherproof
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Exposure Range
- 1/5 sec - 1/32000 sec
- Infrared Distance
- 15 m
- Video Capture
- 1920 x 1080 @ 15 fps , 1280 x 800 @ 30 fps , 1280 x 720 @ 30 fps , 640 x 480 @ 30 fps , 320 x 240 @ 30 fps
- Supported Image Formats
- JPEG
Image Sensor
- 2 MP CMOS 1/2.7"
Lens Construction
- Focal Length
- 4 mm
- Lens Iris
- F/1.5 fixed iris
- Horizontal Field of View (degree)
- 77.4
- Vertical Field of View (degree)
- 45.1
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, SMTP, TCP/IP, UDP/IP, ICMP, SNMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, PPPoE, IGMP, Samba, QOS, CoS
- 1 x network / power - Ethernet 10Base-T/100Base-TX , 1 x camera - RS-485
- FCC Class A certified, C-Tick, ICES-003, IEC 60529 IP66, IP66
- Power Requirements
- Software Included
- Drivers & Utilities, D-ViewCam
- -20 °C
- 50 °C
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
