Experience complete control with the ultra-smooth pan & tilt, HD quality and auto-recording functionality of the DCS-5030L. Monitor your home or small business from your smartphone or tablet.
Pan & tilt
With sharp, responsive pan & tilt movement and 10x digital zoom, you can quickly scan a wide area and zoom in to see more details. -
HD video quality
The HD pan & tilt Wi-Fi camera delivers 720p HD video clarity, ensuring rich detail and crisp image quality for your surveillance recordings. -
Motion detection with automatic recording
The DCS-5030L detects movement - automatically sending an email or push alert to your mobile device. With the microSD card slot, you can also schedule auto-recording straight to any microSD card up to 32 GB. -
Night Vision technology
The HD pan & tilt Wi-Fi camera remains vigilant 24/7 with night vision capability, allowing you to see up to 26 feet in complete darkness. -
Easy installation and flexible placement
Setting up your HD pan & tilt Wi-Fi camera is easier than ever with our app-enabled installation wizard.
- D-Link DCS-5030L - network surveillance camera
- Network surveillance camera - pan / tilt
- Audio
- Yes: built-in microphone
- 10.91 cm x 11.64 cm x 13.36 cm
- 292.4 g
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1280 x 720
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 720p
- Optical Sensor Type
- CMOS - 1/4"
- Minimum Illumination
- 0 lux - IR , 1 lux - colour , 0.5 lux - B&W
- Focal Length
- 2.38 mm
- Lens Iris
- F/2.2
- Panning Range (degree)
- -170 to +170
- Tilting Range (degree)
- -20 to +90
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Voltage
- DC 5 V
- Date/time stamp, Motion Detection Technology, infrared cut filter, Sound Detection Sensor, Wi-Fi Protected Setup (WPS), text stamp, Event Notification, reset button
- 1-year warranty
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Wired, wireless
- 10.91 cm
- 11.64 cm
- 13.36 cm
- 292.4 g
Camera
- Colour - Day&Night - pan / tilt
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1280 x 720
- Motion Detection
- Video Modes
- 720p
- Digital Zoom
- 4
- Infrared LEDs
- Infrared Distance
- 5 m
- Digital Video Capture Resolution
- 1280 x 720, 640 x 480, 320 x 240
- Frame Rate (max)
- Supported Image Formats
- JPEG
Image Sensor
- CMOS 1/4"
Lens Construction
- Focal Length
- 2.38 mm
- Lens Iris
- F/2.2
- Horizontal Field of View (degree)
- 94.36
- Vertical Field of View (degree)
- 59.3
Panning
- Range (degree)
- -170 to +170
Tilting
- Range (degree)
- -20 to +90
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, UPnP, IPv4, PPPoE, LLTD
- Ports
- LAN - RJ-45
- Supported Memory Cards
- microSD Card
- Included Accessories
- Stand
- FCC Class B certified, ICES, LVD
- Power Requirements
- DC 5 V
- Power Device
- Power adapter - external 5.56 Watt
- OS Required
- Apple MacOS X 10.7 or later, Microsoft Windows Vista / 7 / 8 / 10
- Limited warranty - parts and labour - 1 year
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
