D-Link DCS-2530L Wide Eye Full HD 180-degree Panoramic Camera
Quicklinx: CV0CWS00 Mfr#: DCS-2530L
  • microSDHC Card
  • microSD Card
The DCS-2530L Full HD 180-degree Wi-Fi network camera boasts a horizon-wide 180° lens, that easily captures your entire room, wall-to-wall, in high-quality 1080p. Its rotatable head makes ceiling installations easy, and the built-in night vision, motion and sound detection empower you with knowing exactly, what is happening, day or night.
  • Watch over more of your home, day and night
    Get whole-room coverage with a 180 degree wide angle lens and night vision, that lets you watch over your home 24 hours a day.
  • High-quality surveillance and detection
    1080p video ensures you capture the details you need, and sound and motion detection can send snapshots or video clips right to your e-mail inbox.
D-Link DCS 2530L - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in microphone
6.6 cm x 6.6 cm x 10.96 cm
105 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS - 1/3"
Minimum Illumination
0 lux - IR , 0.1 lux - B&W , 0.5 lux - colour
Focal Length Control
Fixed focal
Focal Length
1.7 mm
Focus Adjustment
(min distance 30 cm)
Lens Iris
F/2.5
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 5 V
Date/time stamp, sharpness control, progressive scanning, saturation control, brightness control, contrast control, image flip, image mirror, USB powered, Motion Detection Technology, light sensor, infrared cut filter, Privacy Mask Function, Sound Detection Sensor, hue control, Wi-Fi Protected Setup (WPS), reset button, Text Caption Overlay, password protection
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wireless
6.6 cm
6.6 cm
10.96 cm
105 g
Camera
Colour - Day&Night - fixed
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Infrared LEDs
Infrared Distance
5 m
Video Capture
1920 x 1080 @ 15 fps , 1280 x 720 @ 30 fps , 800 x 448 @ 30 fps , 640 x 360 @ 30 fps
Supported Image Formats
JPEG
Image Sensor
CMOS 1/3"
Lens Construction
Fixed focal
Focal Length
1.7 mm
Lens Iris
F/2.5
Min Focus Distance
30 cm
Horizontal Field of View (degree)
180
Vertical Field of View (degree)
86
Network Interface
Network Protocols
DDNS, DHCP, DNS, HTTP, NTP, SMTP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP
Ports
USB (power only) - Micro-USB Type B
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
FCC, ICES, LVD
Power Requirements
DC 5 V - 1.2 A
Power adapter - external AC 120/230 V (50/60 Hz) 4.5 Watt
Apple MacOS X 10.7 or later, Microsoft Windows 7 / 8 / 10
Relative Humidity (operating)
