The DCS-2530L Full HD 180-degree Wi-Fi network camera boasts a horizon-wide 180° lens, that easily captures your entire room, wall-to-wall, in high-quality 1080p. Its rotatable head makes ceiling installations easy, and the built-in night vision, motion and sound detection empower you with knowing exactly, what is happening, day or night.
Watch over more of your home, day and night
Get whole-room coverage with a 180 degree wide angle lens and night vision, that lets you watch over your home 24 hours a day. -
High-quality surveillance and detection
1080p video ensures you capture the details you need, and sound and motion detection can send snapshots or video clips right to your e-mail inbox.
- D-Link DCS 2530L - network surveillance camera
- Network surveillance camera - fixed
- Audio
- Yes: built-in microphone
- 6.6 cm x 6.6 cm x 10.96 cm
- 105 g
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- CMOS - 1/3"
- Minimum Illumination
- 0 lux - IR , 0.1 lux - B&W , 0.5 lux - colour
- Focal Length Control
- Fixed focal
- Focal Length
- 1.7 mm
- Focus Adjustment
- (min distance 30 cm)
- Lens Iris
- F/2.5
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Voltage
- DC 5 V
- Date/time stamp, sharpness control, progressive scanning, saturation control, brightness control, contrast control, image flip, image mirror, USB powered, Motion Detection Technology, light sensor, infrared cut filter, Privacy Mask Function, Sound Detection Sensor, hue control, Wi-Fi Protected Setup (WPS), reset button, Text Caption Overlay, password protection
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Wireless
- 6.6 cm
- 6.6 cm
- 10.96 cm
- 105 g
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Infrared LEDs
- Infrared Distance
- 5 m
- Video Capture
- 1920 x 1080 @ 15 fps , 1280 x 720 @ 30 fps , 800 x 448 @ 30 fps , 640 x 360 @ 30 fps
- Supported Image Formats
- JPEG
Image Sensor
- CMOS 1/3"
Lens Construction
- Fixed focal
- Focal Length
- 1.7 mm
- Lens Iris
- F/2.5
- Min Focus Distance
- 30 cm
- Horizontal Field of View (degree)
- 180
- Vertical Field of View (degree)
- 86
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, HTTP, NTP, SMTP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP
- Ports
- USB (power only) - Micro-USB Type B
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- FCC, ICES, LVD
- Power Requirements
- DC 5 V - 1.2 A
- Power Device
- Power adapter - external AC 120/230 V (50/60 Hz) 4.5 Watt
- OS Required
- Apple MacOS X 10.7 or later, Microsoft Windows 7 / 8 / 10
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
