Product
D-Link DCS-2332L Outdoor HD Wireless Day/Night Cloud Camera
Quicklinx: 8VK9WS00 Mfr#: DCS-2332L/B
The DCS-2310L and DCS-2332L Cloud Cameras are built for outdoor use, with weatherproof housing that protects them from dust and rain. A megapixel image sensor gives you high-quality snapshots and video with resolutions of up to 720p HD. You can even get a closer look with ePTZ viewing, which lets you zoom in, zoom out, and pan across, so you can survey a large area easily.
mydlink™ Cloud Services: the easiest way to monitor your home
Connecting a camera to your network and accessing it has traditionally required complex configuration. mydlink™ Cloud Services makes it easy to access your camera from wherever you are, whenever it's convenient for you. A step-by-step guide has your camera up and running in a matter of minutes. Then via a simple website you can set up a mydlink™ account allowing you to view and manage your camera from any Internet connected computer. If you have more than one camera, you can add it to your existing mydlink™ account and watch all your cameras from a single location. Accessing your cameras on the go is easy too. Just download the free mydlink™ app for your iPhone®, iPad® or Android™ devices and you can quickly and easily view your camera feed from anywhere with a wireless or 3G connection. If you have multiple cameras, you can download the mydlink™+ app which allows you to monitor up to 4 cameras on one screen on your tablet
24/7 HD Surveillance
These Cloud Cameras have a megapixel image sensor to give you high-quality snapshots and video with resolutions of up to 720p HD.. Get a closer look with ePTZ, which lets you zoom in, zoom out, and pan across your camera's video so you can survey a large area easily. An infrared cut removable (ICR) filter is also built into these Cloud Cameras, which blocks infrared light during the day for improved image quality. At night, it moves out of the way to use all available light for low-light surveillance, and paired with the IR LED illuminator, these cameras can monitor an area even in complete darkness.
Built for the outdoors
The Power over Ethernet Camera allows you to connect to your network and power it through a single cable, simplifying deployment and doing away with the need for a nearby power outlet. The Wireless Camera is good for those places where a power source is readily available, but running a network would be difficult or unsightly, for instance, to a shed or garage. Both cameras offer you HD quality and are built for outdoor use, these cameras have an IP65 weatherproof housing that protects it from dust and rain.
Zero Configuration
If you have a D-Link Cloud Router, setting up and configuring your Cloud Camera is easy, thanks to Zero Configuration. Simply connect your camera to its power adapter and then connect your camera to your Cloud Router with an Ethernet cable -the camera will automatically be added to your mydlink™ account. Setting up cameras has never been so easy.
Built for versatility
Both Outdoor Cloud Cameras comes with a wealth of features that enhance their home monitoring capabilities, making them ideal for any situation. A passive infrared (PIR) sensor detects motion near the camera, allowing it to automatically record video and send you a notification when motion is detected. A built-in microphone and speaker allow for 2-way communication, which is ideal for use in entryways.
A complete, surveillance solution
These HD Cloud Cameras are a self-sufficient home monitoring solution, capable of recording snapshots and video to a MicroSD card* without requiring a PC or network storage device. If you want to expand your surveillance options, D-View Cam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features, including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities.
*microSD not included
  • 24/7 HD surveillance
    These cloud cameras have a megapixel image sensor to give you high-quality snapshots and video with resolutions of up to 720p HD. This gives you sharp, high-resolution snapshots and videos with rich detail. Get a closer look with ePTZ, which lets you zoom in, zoom out, and pan across so you can survey a large area easily. An infrared cut removable (ICR) filter is also built into these Cloud Cameras, which blocks infared light during the day for improved image quality. At night, it moves out of the way to use all available light for lowlight surveillance, and paired with the IR LED illuminator, these cameras can monitor an area even in complete darkness.
  • Built for the outdoors
    The Power over Ethernet camera allows you to connect to your network and power it through a single cable, simplifying deployment and doing away with the need for a nearby power outlet. The Wireless Camera is good for those places where a power source is readily available, but running a network would be difficult or unsightly, for instance, to a shed or garage. Both cameras offer you HD quality and are built for outdoor use, these cameras have an IP-65 weatherproof housing that protects it from dust and rain.
  • Zero configuration
    If you have a mydlink enabled cloud router, setting up and configuring your Cloud Camera is easy, thanks to zero configuration. Simply connect your camera to its power adapter and then connect your camera to your cloud router with an Ethernet cable - the camera will automatically be added to your mydlink account. Setting up cameras has never been so easy.
  • Built for versatility
    These cloud cameras come with a wealth of features that enhance its surveillance capabilities, making it ideal for any situation. A passive infrared (PIR) sensor detects motion near the camera, allowing it to automatically record video and send you a notification when motion is detected. A built-in microphone and speaker allow for 2-way communication, which is ideal for use in entryways.
D-Link DCS 2332L HD Wireless Outdoor Cloud Camera - network surveillance camera
Network surveillance camera - fixed - outdoor - weatherproof
Audio
Yes: built-in speaker, built-in microphone
235 g
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
0 lux - IR
Focal Length
3.45 mm
Lens Iris
F/2.0
Ethernet 10Base-T/100Base-TX, IEEE 802.11n
Voltage
DC 5 V
IR filter, sharpness control, progressive scanning, saturation control, brightness control, Power over Ethernet, contrast control, SDHC-card slot, ONVIF support, Privacy Mask Function
Environmental Parameters (operating)
-25 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wired, wireless
235 g
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Digital Zoom
10
0 lux - IR
Infrared LEDs
Video Capture
1280 x 800 @ 30 fps , 1280 x 720 @ 30 fps , 800 x 450 @ 30 fps , 640 x 360 @ 30 fps , 480 x 270 @ 30 fps , 320 x 176 @ 30 fps , 176 x 144 @ 30 fps , 1024 x 768 @ 30 fps , 800 x 600 @ 30 fps , 640 x 480 @ 30 fps , 480 x 360 @ 30 fps , 320 x 240 @ 30 fps , 176 x 144 @ 30 fps
Supported Image Formats
JPEG
Image Sensor
CMOS 1/4"
Lens Construction
Focal Length
3.45 mm
Lens Iris
F/2.0
Horizontal Field of View (degree)
57.8
Vertical Field of View (degree)
37.8
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, PPPoE, IGMP, Samba, QOS, CoS
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Stand
C-Tick, IC, FCC, IP65
Power Requirements
DC 5 V
Power adapter - external AC 120/230 V (50/60 Hz) 5.3 Watt
Microsoft Windows Vista / XP / 7
-25 °C
50 °C
Relative Humidity (operating)
8VK9 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
8VK9 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.35
8VK9 C2G 2m Cat6a Shielded Patch - Blue In Stock £7.02
