The D-The D-Link DCS-2230L Full HD Wireless Day/Night Network Camera is a versatile camera perfect for monitoring low-light environments in your home or small office. It combines a high-resolution 2-megapixel sensor with a built-in IR LED to help you keep watch over areas in complete darkness.
Wireless N connectivity
The DCS-2230 includes 802.11n wireless for fast and easy integration into your existing network environment. Wireless N allows you to stream high-quality video to remote sites and mobile devices. A Site Survey feature also allows you to view and connect to nearby wireless networks with ease. The DCS-2230 also includes a standard Ethernet port for connections to traditional wired networks. -
ePTZ for surveying regions of interest
The ePTZ feature allows users to select a target region for close-up viewing simply by clicking on the video feed displayed within their browser. ePTZ makes use of the camera's 2 mexapixel resolution to survey a large area effortlessly. Since ePTZ requires no moving parts, there is no need to worry about the camera having mechanical failures. -
Easy to configure and operate
This network camera supports the Universal Plug-and-Play feature, which allows computers running on Windows XP/Vista/7 to automatically recognize the camera and add it to the network. Sign up with one of the free Dynamic DNS services available on the web to assign a name and domain to the camera, and remotely access the camera without having to remember your IP address. You may also view up to 32 cameras from a central location using the included D-ViewCam software. D-ViewCam has a robust set of features including automated e-mail alerts which can instantly inform administrators of suspicious or unusual activities. -
Open Network Video Interface Forum (ONVIF) compliant
The Open Network Video Interface Forum (ONVIF) is standards relating to open IP video networking. DCS-2230 is ONVIF compliant and therefore interoperable with other manufacturer's products on the same network such as cameras, storage systems, video analytics products and Video Management Systems. For more information on ONVIF and compatible D-Link network cameras, please click here. -
Centralized management with D-ViewCam
The included D-Link D-ViewCam (DCS-100) is a sophisticated video management software which enables you to manage up to 32 network cameras, set email alert notifications, create recording schedules, and trigger motion detection to record directly to your hard drive or network folder. D-ViewCam also allows you to upload a floor plan of your premises, and create a realistic layout according to the locations of your cameras, further simplifying the management process.
- D-Link DCS-2230L Full HD Wireless Day/Night Network Camera - network surveillance camera
- Network surveillance camera - fixed
- Audio
- Yes: built-in speaker, built-in microphone
- 75 g
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Optical Sensor Type
- CMOS - 1/2.7" - 2 MP
- Minimum Illumination
- 0 lux - IR - F2.0
- Focal Length Control
- Fixed focal
- Focal Length
- 2.8 mm
- Lens Iris
- F/1.8
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Cables Included
- 1 - network cable - external
- Voltage
- DC 5 V
- Date/time stamp, sharpness control, saturation control, contrast control, ONVIF support, infrared cut filter, Privacy Mask Function, Wi-Fi Protected Setup (WPS), text stamp, passive infrared sensor, reset button, password protection
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Wired, wireless
- 75 g
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Digital Zoom
- 10
- 0 lux - IR - F2.0
- Infrared LEDs
- Infrared Distance
- 5 m
- Digital Video Capture Resolution
- 1280 x 720, 640 x 480, 1280 x 960, 320 x 240, 1024 x 768, 176 x 144, 1440 x 1080, 800 x 600, 1920 x 1080, 640 x 360, 320 x 176, 800 x 450, 480 x 270
- Frame Rate (max)
- Supported Image Formats
- JPEG
Image Sensor
- 2 MP CMOS 1/2.7"
Lens Construction
- Fixed focal
- Focal Length
- 2.8 mm
- Lens Iris
- F/1.8
- Horizontal Field of View (degree)
- 103
- Vertical Field of View (degree)
- 55
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, Bonjour, RTCP, PPPoE, IGMP, Samba, QOS, CoS
- Ports
- LAN - RJ-45
- Supported Memory Cards
- microSD Card, microSDHC Card
- Cables Included
- 1 x network cable - external
- FCC Class B certified, C-Tick
- Power Requirements
- DC 5 V
- Power Device
- Power adapter - external AC 120/230 V (50/60 Hz) 4 Watt
- Software Included
- Drivers & Utilities
- OS Required
- Apple MacOS X 10.5 or later, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
