The D-Link DCS-2210L Full HD PoE Day/Night Network Camera is a versatile camera perfect for monitoring low-light environments in your home or small office. It combines a high-resolution 2-megapixel sensor with a built-in IR LED to help you keep watch over areas in complete darkness.
Full HD Resolution
The DCS-2210L Full HD PoE Day/Night Network Camera is equipped with a 2 megapixel progressive scan CMOS sensor that provides full HD 1920x1080 resolution, the video stream captures a larger scene and provides more details than an analog CCTV camera - so you can identify criminals more easily in critical surveillance applications. -
Power over Ethernet for convenience
The DCS-2210L supports 802.3af Power over Ethernet (PoE), which lets you power your camera with any Ethernet cable. This feature lets you set up your camera easily without worrying about available power outlets at your location. -
IR LED for day and night functionality
The built-in IR-cut filter and IR LED enable night time viewing or recording in dark environments at ranges up to 16 feet (5 meters). -
DI/DO for connecting external devices
Rounding out the flexibility of the DCS-2210L, you can connect an alarm or trigger to its DI/DO port for integration into a surveillance solution. -
Remote monitoring utility
The D-ViewCam application adds enhanced features and functionality for the DCS-2210L and allows administrators to configure and access the DCS-2210L from a remote site via Intranet or Internet. Other features include image monitoring, recording images to a hard drive, viewing up to 32 cameras on one screen, and taking snapshots. -
Built-in microphone and speaker
Covering all the visual components, the DCS-2210L also has a built-in microphone and speaker, so you can transmit two-way audio easily. -
Web configuration
Using a standard web browser, administrators can configure and manage the DCS-2210L directly from its own web page via Intranet or Internet. This means you can access your DCS-2210L anytime, anywhere in the world. -
Broad range of applications
With today's high-speed Internet services, the DCS-2210L can provide the ideal solution for delivering live video images over the Intranet and Internet for remote monitoring. The DCS-2210L allows remote access using a web browser for live image viewing, and allows the administrator to manage and control the DCS-2210L anytime, anywhere in the world.
- D-Link DCS-2210L Full HD PoE Day/Night Network Camera - network surveillance camera
- Network surveillance camera - fixed
- Audio
- Yes: built-in speaker, built-in microphone
- 5.8 cm x 8.9 cm x 12.79 cm
- 80 g
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Optical Sensor Type
- CMOS - 1/2.7"
- Minimum Illumination
- 0 lux - IR
- Lens Iris
- F/1.8
- Ethernet 10Base-T/100Base-TX
- Cables Included
- 1 - network cable - external
- Voltage
- DC 5 V / PoE
- Date/time stamp, IR filter, sharpness control, saturation control, contrast control, ONVIF support, Privacy Mask Function, Wi-Fi Protected Setup (WPS), text stamp, LED indicator
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Wired
- 5.8 cm
- 8.9 cm
- 12.79 cm
- 80 g
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Digital Zoom
- 10
- 0 lux - IR
- Infrared LEDs
- Video Capture
- 1920 x 1080 @ 30 fps , 1440 x 1080 @ 30 fps , 1280 x 720 @ 30 fps , 800 x 450 @ 30 fps , 640 x 360 @ 30 fps , 480 x 270 @ 30 fps , 1280 x 960 @ 30 fps , 1024 x 768 @ 30 fps , 800 x 600 @ 30 fps , 640 x 480 @ 30 fps , 320 x 240 @ 30 fps
Image Sensor
- CMOS 1/2.7"
Lens Construction
- Lens Iris
- F/1.8
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, HTTPS, UPnP, Bonjour, RTCP, PPPoE, IGMP, Samba, QOS, CoS
- Alarm Inputs Qty
- 1
- Alarm Outputs Qty
- 1
- Supported Memory Cards
- SD Memory Card, SDHC Memory Card
- Cables Included
- 1 x network cable - external
- C-Tick, FCC, LVD
- Power Requirements
- DC 5 V / PoE
- Power Device
- Power adapter - external AC 120/230 V (50 - 60 Hz) 3.5 Watt
- Software Included
- Drivers & Utilities
- OS Required
- Apple MacOS X 10.5 or later, Microsoft Windows Vista / XP / 7 / 8
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
