Product
D-Link DCH-S150/B mydlink Home Wi-Fi Motion Sensor
Quicklinx: 9T7VWS00 Mfr#: DCH-S150/B
Type: Motion sensor
10 in stock
£35.32 ex VAT
£42.38 inc VAT
Standard delivery Delivered within 3-5 working days
Make Your Home React to Motion.
Meet the Wi-Fi Motion Sensor. It lets you know when motion is detected at home. Pair it with Smart Plugs and Home Monitors to do amazing things around your home.
When Something's Moving, You'll Know
Get push or text notifications on your smartphone when motion is detected at home. But it's what you can do next that's really exciting.
Devices that React to You? That's Magic
Imagine opening your door after a night out. The lights turn on and your favourite song begins to play. Magic? Nope. When you pair your Wi-Fi Motion Sensor with a Wi-Fi Smart Plug, your home reacts to you in amazing ways.
Your Home in Your Hand
Something moving at home? It's probably just the dog or the delivery man but you shouldn't have to wonder. Your Wi-Fi Motion Sensor works with your mydlink™ Home Monitor so that whenever motion is detected, you can view what's happening right on your smartphone.
Works with mydlink™ Home Monitor 360 & mydlink™ Home Monitor HD.
How It Works
Plug in your Wi-Fi Motion Sensor
Press the WPS button to connect to your home network
Know what's happening at home, Works with What You Have, Easily connects with your existing Wi-Fi network.
The Possibilities Are Endless
Add Wi-Fi Smart Plugs to other rooms, your work place, or a vacation home.
  • the mydlink™ Home app is available for iPod touch, iPhone and iPad devices using iOS version 6.0 or later, and Android devices using Android version 4.0 or later.
  • Make your home react to motion
    Meet the Wi-Fi motion sensor. It lets you know when motion is detected at home. Pair it with smart plugs and home monitors to do amazing things around your home.
  • That's magic
    Imagine opening your door after a night out. The lights turn on and your favorite song begins to play. Magic? Nope. When you pair your Wi-Fi motion sensor with a smart plug, your home reacts to you in amazing ways.
  • Your home in your hand
    Something moving at home? It's probably just the dog or the delivery man but you shouldn't have to wonder. Your Wi-Fi motion sensor works with your mydlink home monitor so that whenever motion is detected, you can view what's happening right on your smartphone.
  • Works with what you have
  • The possibilities are endless
    Add Wi-Fi smart plugs to other rooms, your work place, or a vacation home.
mydlink Home Smart Plug - motion sensor
Motion sensor
Wireless - 802.11b/g/n
Supported Host Device OS
iOS, Android
5.8 cm x 43.5 cm x 5.4 cm
Motion sensor
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
iOS, Android
Push notification Wi-Fi Protected Setup (WPS)
Internet of Things (IoT)
Communications Type
Cloud
Communications Technology
WiFi
Motion Sensor
Detection Mode
Passive infrared (PIR)
Detection Range
8 m
Aerial
Internal
Quantity
1
Encryption Algorithm
WPA, WPA2
UL, FCC, LVD
5.8 cm
43.5 cm
5.4 cm
80 g
10 - 90% (non-condensing)
Type: Motion sensor
Brand: D-Link
Price Range Ex VAT: 0 - 50
