The DCS-933L Day/Night Cloud Camera is a versatile surveillance solution for your home or office. Unlike a standard webcam, the DCS-933L is a standalone system that can transmits high quality video images, without the need of a computer. Furthermore, the built-in wireless extender function improves your existing wireless network to give your home or office a more complete wireless coverage.
24/7 Day and Night Monitoring
The DCS-933L is a standalone surveillance camera that can run without the need of a computer and requires no special hardware or software. When connected to the Internet, the DCS-933L can send e-mail notifications with snapshots or video clips whenever motion or sound is detected. You can choose areas of interest for motion detection or set the sound volume level for when you want to be alerted. Night time monitoring is possible with the built-in infrared LEDs which allow for night time viewing of up to 5 metres, enabling round-the-clock monitoring, even in complete darkness.
mydlink™: the easiest way to setup up your camera and monitor your home
Connecting a camera on your network and accessing it has traditionally required complex configuration. mydlink™ makes it easy to access your camera from wherever you are, whenever it's convenient for you. Using the free mydlink™ Lite app for iOS and Android smartphones and tablets, you can connect and setup your mydlink™ camera without the need of a computer. A step-by-step guide has your camera up and running in a matter of minutes. Through the mydlink™ Lite app, you can set up a free mydlink™ account allowing you to view and manage your camera from any Internet connected computer. If you have more than one camera, you can add it to your existing mydlink™ account and watch all your cameras from a single location.
Accessing your cameras on the go is easy too. Just download the free mydlink™ app for your iPhone or Android and you can quickly and easily view your camera feed from anywhere with a wireless or 3G/4G LTE connection. Thanks to this app, you can monitor on-the-go even if you don't have access to a computer.
Wireless N Connectivity and Extender
Not only can the DCS-933L connect via wireless N to your WPS-enabled router with a single press of a button, the extender mode can extend the range of your existing wireless network. This eliminates wireless dead spots to give your home or office a more complete wireless coverage.
Full Featured Surveillance System
Included with the DCS-933L is the free D-ViewCam™ software. D-ViewCam™ IP camera surveillance software is a comprehensive surveillance system designed to centrally manage multiple IP cameras. Supporting up to 32 IP cameras, D-ViewCam™ is compatible with all current D-Link IP cameras and provides digital monitoring and recording of video, audio, and events for various security applications. This software provides users with a wide array of features for added convenience, including video recording and playback, Video mode, Map mode, Wizard mode, Expert mode, Event Action, and more.
The DCS-933L is ideal for anyone looking for a security camera, Internet camera or remote camera, as well as businesses looking to set up a CCTV or video surveillance system.
Keep an eye on what matters most
The DCS-933L provides true around-the-clock surveillance so you can check in on your home or office from wherever you are. Simply log-in to your account with an Internet browser or mydlink mobile app available for iOS and Android devices, and start viewing. The DCS-933L comes fully-equipped with H.264 enhanced video compression that allows you to record up to 5x more footage to the built-in microSD card slot, when compared to MJPEG. It also comes with enhanced motion detection and night vision features that let you see up to 15 feet in pitch black darkness. -
Extend your wireless network
The DCS-933L comes with a built-in Wi-Fi extender, providing a convenient way to expand your wireless network. Simply place your camera somewhere within range to instantly increasing your wireless home coverage. While the DCS-933L provides great value in home monitoring, it is also an easy way to eliminate dead spots within your home. -
Zero configurations
Connecting your D-Link camera to any router is quick and easy - with a D-Link Cloud Router, setup is made even easier. D-Link's lineup of Cloud Cameras and Routers come box-ready with automatic configuration and intelligent syncing so all you have to do is connect and view.
- D-Link DCS 933L Day/Night Cloud Camera - network surveillance camera
- Network surveillance camera - fixed
- Audio
- Yes: built-in microphone
- 8 cm x 8 cm x 11.5 cm
- 96.2 g
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 640 x 480
- Optical Sensor Type
- CMOS - 1/5"
- Minimum Illumination
- 0 lux - IR
- Focal Length
- 3.15 mm
- Lens Iris
- F/2.8
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Voltage
- DC 5 V
- Date/time stamp, saturation control, brightness control, contrast control, Wi-Fi Protected Setup (WPS), text stamp, built-in Wi-Fi extender
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Wired, wireless
- 8 cm
- 8 cm
- 11.5 cm
- 96.2 g
- Localisation
- United Kingdom
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 640 x 480
- Digital Zoom
- 4
- Exposure Range
- 1/15 sec - 1/15000 sec
- 0 lux - IR
- Infrared LEDs
- Video Capture
- 160 x 112 @ 30 fps , 320 x 240 @ 30 fps , 640 x 480 @ 30 fps
Image Sensor
- CMOS 1/5"
Lens Construction
- Focal Length
- 3.15 mm
- Lens Iris
- F/2.8
- Horizontal Field of View (degree)
- 45.3
- Vertical Field of View (degree)
- 34.5
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, UPnP, IPv4, PPPoE
- 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
- Included Accessories
- Stand
- C-Tick, FCC
- Power Requirements
- DC 5 V - 1 A
- Power Device
- Power adapter - external AC 120/230 V (50/60 Hz) 4 Watt
- Software Included
- D-ViewCam
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
