D-Link DAP-1665 Wireless AC1200 Dual Band Access Point
Clearance!
Clearance
Last Few Remaining
Limited Time Offer
Quicklinx: 9TSSWS00 Mfr#: DAP-1665
Type: Radio access point
Connectivity: Wireless
Protocol: IEEE 802.11a, IEEE 802.11ac (draft), IEEE 802.11b, IEEE 802.11g + 1 more
Compatibility: PC
  • IEEE 802.11n
10 in stock
£58.69 ex VAT
£70.42 inc VAT
The DAP-1665 Wireless AC1200 Dual-Band Access Point is a fast and versatile solution for bringing Wireless AC to your existing wired network, or extending your current wireless network. The latest 802.11ac technology delivers combined speeds of up to 1200 Mbps, so you can create a high-speed wireless link between networks, or quickly transfer large files wirelessly between computers on the same network.
  • High-speed wireless and wired LAN
    The DAP-1665 features the 802.11ac wireless technology, capable of delivering combined speeds of up to 1200 Mbps over two bands. Use the 2.4 GHz band's 300 Mbps for web surfing, email and chat, while simultaneously using the lower-interference 5 GHz band for network bridging, downloading, and file transfers. For wired connections, the Gigabit LAN port enables wired data speeds of up to 1000 Mbps, meaning that your Gigabit-compatible wired devices can also benefit from the high speeds of wireless AC.
  • Versatile operation modes
    The DAP-1665 can be configured to operate in several modes, allowing you to customize it to your networking needs. Access point mode allows the device to act as a central hub for wireless users, giving them access to your existing wired network. Wireless client mode is available to enable the DAP-1665 to connect to another access point and provide network and Internet access to a remote wired device such as a gaming console or media center. Bridge mode allows you to create a high-speed wireless link between two wired networks (LANs), alleviating the need to install additional network cabling. Bridge mode with AP adds the functionality of a wireless access point to your bridged network, so wireless clients can access resources on both networks. Repeater mode extends wireless coverage of your existing wireless network to cover "dead" spots and reach farther into your home or office.
  • Full wireless security
    The DAP-1665 provides 64/128-bit WEP encryption and WPA/WPA2 security to protect your network and wireless data. This device also supports Wi-Fi Protected Setup (WPS) to quickly and securely set up a secure wireless network. In addition, the access point features MAC address filtering and a disable SSID broadcast function to limit outsiders' access to your wireless network. The DAP-1665 also features a Kensington security slot so you can protect your access point against theft.
D-Link DAP-1665 - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
Frequency Band
2.4 GHz, 5 GHz
14.7 cm x 10.8 cm x 2.78 cm
222 g
Radio access point
14.7 cm
10.8 cm
2.78 cm
222 g
External
Wireless
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, wireless
128-bit encryption, 64-bit encryption, MAC address filtering, Wi-Fi Protected Setup (WPS), wireless bridge mode
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna
External detachable
Antenna Qty
2
Gain Level
2 dBi
1 x 1000Base-T - RJ-45
VCCI, IC, FCC, TELEC
External power adapter
5.18 Watt
10 - 90% (non-condensing)
9TSS C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
9TSS C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.18
9TSS C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.47
9TSS C2G 2m Cat6a Shielded Patch - Blue In Stock £7.05
Protocol: IEEE 802.11ac (draft)
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: D-Link
Price Range Ex VAT: 50 - 100
