D-Link DAP-1520/B Wireless AC750 Dual Band Range Extender
Quicklinx: B6TWWS00 Mfr#: DAP-1520/B
  • IEEE 802.11n
The DAP-1520 Wireless AC750 Dual-Band Range Extender is a portable plug-in wireless repeater that lets you extend an existing wireless network. You can place it anywhere in your home to increase the range of your wireless network. Tiny yet powerful, it supports Wireless AC speeds of up to 750 Mbps, yet fits in the palm of your hand.
Increase the coverage of your home Wireless network with the sleek and easy-to-use DAP-1520 Wireless AC750 Dual-Band Range Extender. Dual-band technology helps reduce interference from nearby wireless transmitters in the home, and also provides backward compatibility with older wireless devices in your network, allowing you to enjoy a blazing-fast, reliable wireless connection.
Setting up the Wireless AC750 Dual-Band Range Extender is simple. You can use the supported QRS Mobile app on your iOS or Android mobile device to set up the DAP-1520 easily without needing a computer. Alternatively, you can use one-touch configuration by pushing the WPS push-button on the DAP-1520 and on the router or AP you want to extend, and the DAP-1520 will automatically configure itself for you. It even includes a built-in setup wizard that lets you configure it wirelessly with a PC or mobile device.
The DAP-1520 is a compact device that is ideal for use at home or in a small office, as it does not take up much space and is ready to use by simply plugging it in. Its diminutive wall-plug design easily plugs into a power outlet without blocking other outlets and saves you the hassle of dealing with a power cord. Its sleek, unobtrusive appearance blends easily into the decor of your home or office.
  • Extend your wireless network
    Increase the coverage of your home Wireless AC network with the sleek and easy-to-use DAP-1520 Wireless AC750 Dual Band Range Extender. Dual-band technology helps reduce interference from nearby wireless transmitters in the home, and also provides backward compatibility with older wireless devices in your network, allowing you to enjoy a blazing-fast, reliable wireless connection.
  • Easy to set up, easy to use
    Setting up the Wireless AC750 Dual Band Range Extender is simple. Alternatively, you can use one-touch configuration by pushing the WPS push-button on the DAP-1520 and on the router or AP you want to extend, and the DAP-1520 will automatically configure itself for you. It even includes a built-in setup wizard that lets you configure it wirelessly with a PC or mobile device.
  • Compact, convenient design
    The DAP-1520 is a compact device that is ideal for use at home or a small office, as it does not take up much space and is ready to use by simply plugging it in. Its diminutive wall-plug design easily plugs into a power outlet without blocking other outlets and saves you the hassle of dealing with a power cord. Its sleek, unobtrusive appearance blends easily into the decor of your home or office.
D-Link DAP-1520 - Wi-Fi range extender - Wi-Fi 5
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
Frequency Band
2.4 GHz, 5 GHz
5.8 cm x 3.42 cm x 9.2 cm
104 g
5.8 cm
3.42 cm
9.2 cm
104 g
United Kingdom
External
Wireless
Data Transfer Rate
750 Mbps
Remote Management Protocol
HTTP
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status, WPS
Wi-Fi Protected Setup (WPS), reset button
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac (draft)
Aerial
Antenna
Internal
Antenna Qty
2
UL, C-Tick, EMC, IC, FCC, EMI
Internal power supply
10 - 90% (non-condensing)
