D-Link AirPremier N PoE Access Point with Plenum-rated Chassis DAP-2360
Quicklinx: 82LVWS00 Mfr#: DAP-2360
Type: Radio access point
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Compatibility: PC
  • IEEE 802.11n
14 in stock
£90.60 ex VAT
£108.72 inc VAT
The DAP-2360 is a versatile, high power design access point designed to reduce dead spots and increase capacity. With a white plenum-rated metal chassis, the DAP-2360 allows the access point to blend into ceilings or walls whilst adhering to strict fire codes for placement in air passageways.
  • Versatile Access Point
    The DAP-2360 allows network administrators to deploy a highly manageable and extremely robust 802.11n wireless network. The included antennas are detachable and provide optimal wireless coverage in the 2.4GHz (802.11g and 802.11n) band using a high power single radio design to reduce dead spots and increase capacity. Enclosed in a white plenum-rated metal chassis, the DAP-2360 color allows the access point to easily blend into ceilings or walls and adheres to strict fire codes for placement in air passageways. For advanced installations, this high-speed Access Point has integrated 802.3af Power over Ethernet (PoE) support, allowing installation of this device in areas where power outlets are not readily available.
  • Enhanced Performance
    The DAP-2360 delivers reliable wireless performance with maximum wireless signal rates of up to 300Mbps in the 2.4GHz wireless band. This, coupled with support for Wi-Fi Multimedia (WMM) Quality of Service features, makes it an ideal access point for audio, video, and voice applications. Additionally, the DAP-2360 supports load balancing features to ensure maximum performance by limiting the maximum number of users per Access Point.
  • Security
    To help maintain a secure wireless network, the DAP-2360 provides the latest in wireless security technologies by supporting both Personal and Enterprise versions of WPA and WPA2 (802.11i) with support for RADIUS server backend. To further protect your wireless network, MAC Address Filtering, Wireless LAN segmentation, Disable SSID Broadcast, Rogue AP Detection, and Wireless Broadcast Scheduling are also included. The DAP-2360 includes support for up to 8 VLANs for implementing multiple SSIDs to further help segment users on the network. It also includes a wireless client isolation mechanism, which limits direct client-to-client communication.
  • Multiple Operation Modes
    To maximize total return on investment, the DAP-2360 can be configured to optimize network performance based on any one of its multiple operation modes: Access Point, Wireless Distribution System (WDS) with Access Point, WDS/Bridge (No AP Broadcasting) and Wireless Client. With WDS support, network administrators can set up multiple DAP-2360s throughout a facility and configure them to bridge with one another while also providing network access to individual clients. Also included are advanced features such as Load Balancing, which optimizes high network traffic volume, and redundancy for fail-safe wireless connectivity. Additionally, the DAP-2360 offers Spanning Tree Protocol support for greater efficiency and to avoid broadcast storms when used in WDS mode.
  • Network Management
    Network administrators have multiple options for managing the DAP-2360 including Web (HTTP), Secure Sockets Later (SSL, which provides for a secure connection to the Internet), Secure Shell (SSH, which provides for a secure channel between local and remote computers), and Telnet (bi-directional, eight-bit byte oriented communications facility). For advanced network management, administrators can use the D-Link AP Manager II or D-View management module to configure and manage multiple access points from a single location. In addition to a streamlined management process, the AP Manager II or D-View software provides network administrators with the means of verifying and conducting regular maintenance checks remotely, eliminating the need to send personnel out to physically verify proper operation. With 2.4GHz band functionality, PoE support, a plenum-rated chassis, extensive manageability, versatile operation modes, and solid security enhancements, the D-Link AirPremier N PoE Access Point (DAP-2360) provides SMB environments with a business-class solution for deploying a wireless network in the workplace.
D-Link AirPremier N PoE Access Point with Plenum-rated Chassis DAP-2360 - radio access point
Radio access point
External - indoor
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
16.6 cm x 18.8 cm x 3.7 cm
0.77 kg
Radio access point
Ruggedized Design
Indoor
16.6 cm
18.8 cm
3.7 cm
0.77 kg
External
Wireless
Data Transfer Rate
300 Mbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz
Status Indicators
Power, WLAN
VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, Network Access Protection (NAP)
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna
External detachable
Antenna Qty
2
Gain Level
5 dBi
1 x 1000Base-T - RJ-45
FCC Class B certified, IC, UL 2043
PoE
Limited warranty - lifetime
10 - 90% (non-condensing)
82LV C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.27
82LV C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.18
82LV C2G 2m Cat6a Shielded Patch - Blue In Stock £7.49
Speed: 300Mbps
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: D-Link
Price Range Ex VAT: 50 - 100
