D-Link AC750 Wireless Router
Quicklinx: BKJBWS00 Mfr#: DWR-118
  • IEEE 802.11n
The DWR-118 Wireless AC750 Dual-Band Multi-WAN Router allows you to share superfast 4G LTE/3G mobile Internet simultaneously to your smartphone, tablet, notebook and desktop computer. Universal 4G LTE/3G USB dongle support from any mobile operator, this router is the ideal solution for setting up an Internet connection to share with your colleagues or your family and friends when you are on holiday. Wireless AC allows you to create a fast and secure high speed personal hotspot with wireless speeds of up to 433 Mbps
Simultaneous 4G
LTE/3G mobile Internet and fixed broadband Internet support allows you to combine Internet connections to give you faster Internet speeds. You can also set up fail-safe Internet should either connections fail.
Reliable, Uninterrupted and Faster Internet Connection
Create a load sharing and fail-safe Internet connection with simultaneous 4G LTE/3G mobile Internet and fixed broadband Internet support. A Gigabit Ethernet WAN port allows you to attach a DSL/Cable modem as the primary or backup link, while auto-failover ensures an uninterrupted connection by automatically connecting to your 4G LTE/3G network whenever the WAN link is lost. Load sharing function allows the Internet connections to be combined to give you faster Internet speeds. The built-in QoS management feature also prioritises traffic to ensure that the most important data receives optimum bandwidth.
Incredible Wireless Speeds
The DWR-118 supports the latest, high-speed 4G LTE mobile broadband technology, allowing you to achieve blazing fast mobile broadband speeds. In addition to this, the Wireless AC750 Dual-Band Multi-WAN Router’s AC technology means that you can connect wireless clients to the router at up to 433 Mbps, with the enhanced range and reliability of the dual-band 802.11ac wireless standard.
Advanced Network Security
The DWR-118 ensures a secure Wi-Fi network through the use of WPA/WPA2 wireless encryption. Simply press the WPS button to quickly establish a secure connection to new devices. The DWR-118 also utilises dual-active firewalls (SPI and NAT) to prevent potential attacks and intrusions from across the Internet.
Simple to Install and Use
The Wireless AC750 Dual-Band Multi-WAN Router can be installed quickly and easily almost anywhere. The intuitive setup wizard will get you set up and connected in no time. This router is great for situations where an impromptu wireless network is required, or where conventional wired network access is unavailable. The DWR-118 can even be installed on buses, trains, or boats, allowing passengers to access the Internet while commuting
  • Reliable, uninterrupted and fast Internet connection
    Create a load sharing and fail-safe Internet connection with simultaneous 4G LTE and 3G mobile Internet and fixed broadband Internet support. A Gigabit Ethernet WAN port allows you to attach a DSL or a cable modem as the primary or backup link, while auto-failover ensures an uninterrupted connection by automatically connecting to your 4G LTE and 3G network whenever the WAN link is lost. Load sharing function allows the Internet connections to be combined to give you faster Internet speeds. The built-in QoS management feature also prioritizes traffic to ensure that important data receives optimum bandwidth.
  • High wireless speeds
    The DWR-118 supports high-speed 4G LTE mobile broadband technology, allowing you to achieve blazing fast mobile broadband speeds. In addition you can connect wireless clients to the router at high speed with the enhanced range and reliability.
  • Advanced network security
    The DWR-118 ensures a secure Wi-Fi network through the use of WPA/WPA2 wireless encryption. Simply press the WPS button to quickly establish a secure connection to devices. The DWR-118 also utilizes dual-active firewalls to prevent potential attacks and intrusions from across the Internet.
  • Simple to install and use
    The router can be installed quickly and easily almost anywhere. The intuitive setup wizard will get you set up and connected in no time. This router is great for situations where an impromptu wireless network is required, or where conventional wired network access is unavailable. The DWR-118 can even be installed on buses, trains, or boats, allowing passengers to access the Internet while commuting.
D-Link DWR-118 - wireless router - WWAN - 802.11b/g/n/ac - desktop
Wireless router - wireless cellular modem - 4-port switch (integrated)
Enclosure Type
Desktop
Cellular Protocol
CDMA, UMTS, HSDPA, HSUPA, HSPA+, LTE
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Network / Transport Protocol
PPTP, L2TP, IPSec
NAT support, Stateful Packet Inspection (SPI), MAC address filtering, VPN passthrough, URL filtering, Quality of Service (QoS), Wi-Fi Protected Setup (WPS)
IEEE 802.3, IEEE 802.3u, Wi-Fi CERTIFIED
14.85 cm x 11.35 cm x 2.5 cm
350 g
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
PPTP, L2TP, IPSec
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
IEEE 802.3, IEEE 802.3u, Wi-Fi CERTIFIED, RoHS
Status Indicators
Power, WLAN, WAN, LAN, USB, Internet
Communications
Wireless cellular modem
Cellular Protocol
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
External detachable and internal
Antenna Qty
3
External power adapter
14.85 cm
11.35 cm
2.5 cm
350 g
10 - 95% (non-condensing)
BKJB C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
BKJB C2G 5m USB 2.0 A/B Cable - Black In Stock £5.03
BKJB C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.61
