The DIR-842 Wireless AC1200 Dual Band Gigabit Router combines the latest high-speed 802.11ac dual-band Wi-Fi with Gigabit Ethernet ports to provide a seamless networking experience. The DIR-842's advanced security features keep data safe from unwanted network intruders, whilst the increased range and reliability of Wireless AC technology allows you to stay connected even under heavy network utilization or in rooms that have bad wireless signal.
- D-Link DIR-842 - wireless router - 802.11a/b/g/n/ac - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- PPTP, L2TP, PPPoE, DHCP, DNS, DDNS
- Remote Management Protocol
- HTTP
- Interrupt status port (ISP), IPv6 support, Wi-Fi Protected Setup (WPS), static IP mode, 2T2R MIMO technology, IPv4 support, dynamic IP mode
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Power
- AC 120/230 V (50 - 60 Hz)
- 18.994 cm x 13.297 cm x 3.81 cm
- 288 g
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- HTTP
- Encryption Algorithm
- WPA, WPA2
- Authentication Method
- Radio Service Set ID (SSID)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, CCC, FCC, RoHS
- Status Indicators
- Power, WAN, LAN, wireless, WPS, Internet
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- External detachable
- Antenna Qty
- 4
- Power Device
- External power adapter
- Voltage Required
- Cables Included
- 1 x network cable
- 18.994 cm
- 13.297 cm
- 3.81 cm
- 288 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
