The DGS-1008P offers an economical way for SOHO and small to medium businesses (SMB) to benefit from the increased bandwidth of Gigabit Ethernet. It provides 8 Gigabit ports for fast server deployment to meet increasing network loads. The Gigabit PoE ports provide a larger bandwidth for high speed network applications, especially IEEE802.11n Access Points, high resolution video cameras, and phones.
8-port desktop switch with 4 Power over Ethernet (PoE) ports
The DES-1008P 8-port switch can convey power to up to four network devices via the usual network cables using Power over Ethernet technology. This provides a cost-effective entry-level solution for users wishing to make the most of their network. The DES-1008P enables users to easily connect and supply power to devices such as wireless Access Points (AP), IP cameras and IP phones via the common network cables. -
IEEE 802.3af Power over Ethernet (PoE)
Four out of the eight ports on the DES-1008P support the IEEE 802.3af standard for Power over Ethernet (PoE). Each of these ports can supply up to 15.4W, up to a total PoE budget of 56W, allowing users to attach IEEE 802.3af-compliant devices without requiring an additional power source. Networking devices receiving power in this way do not need to be placed within close proximity of a power outlet, allowing greater flexibility for their placement. Compliance with IEEE 802.3af also means that when a compliant device is attached, the switch automatically adjusts the power supplied to that device. -
Superior performance
The switch is completely unmanaged, so no configuration is required and installation is quick and easy. Support for auto-MDI/MDI-X on all ports eliminates the need for crossover cables for connection to another switch or hub. Auto-negotiation on each port senses the link speed of a network device and intelligently adjusts for compatibility and optimal performance. The DES-1008P also features diagnostic LEDs that display status and activity, allowing you to quickly detect and correct problems on the network. With wire-speed filtering and store-and-forward switching, the DES-1008P also maximizes network performance while minimizing the transmission of bad network packets. Combining the convenience of PoE, superior performance, and ease of use, the D-Link DES-1008P is the ideal choice for adding PoE devices to either a home or a small business network.
- D-Link DGS 1008P - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 4 x 10/100/1000 (PoE) + 4 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE
- Performance
- Switching capacity: 16 Gbps
- MAC Address Table Size
- 4K entries
- Jumbo Frame Support
- 9720 bytes
- Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), packet filtering, store and forward, half duplex mode, QoS, Jumbo Frames support, Cable Diagnostics Function, D-Link Green Technology
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x
- Power
- AC 120/230 V (50/60 Hz)
- 19 cm x 12 cm x 3.8 cm
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- Performance
- 4K entries
- 9720 bytes
- RAM
- 192 KB
- Status Indicators
- Port status, port transmission speed, power, link OK, link/activity
- 4 x 1000Base-T RJ-45 PoE , 4 x 1000Base-T RJ-45
- Power Device
- External power adapter
- Voltage Required
- FCC Class B certified, VCCI Class B ITE, cUL, ICES-003 Class B, C-Tick Class B, RoHS
- 19 cm
- 12 cm
- 3.8 cm
- 0 °C
- 50 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
