D-Link 8-PORT 10/100 SMART POE SWITCH
Quicklinx: 7GQZWS00 Mfr#: DES-1210-08P
Type: Fast Ethernet
Ports: 8
Data Transfer Rate: 100Mbps
Managed: Yes
POE: PoE
£117.26 ex VAT
£140.71 inc VAT
The DES-1210-08P is a PoE switch in the Fast Ethernet Smart series. Equipped with 8 Fast Ethernet ports, this switch integrates the features of the Smart series with PoE functionality. With an easy to use web interface and eco-friendly design, the DES-1210-08P helps customers to quickly and easily deploy their networks, saving energy and money.
The DES-1210-08P is the ideal solution as an advanced edge switch for SMB and enterprise networks. The Asymmetric VLAN support will provide access to shared resources such as servers or the Internet, without complicated VLAN configurations. Additionally, the innovative AutoVoice and AutoSurveillance VLAN features allow for easy integration of 3rd party IP phones and network cameras, placing traffic from these devices in separate VLANs.
The DES-1210-08P complies with the 802.3af PoE standard. This gives you extra flexibility at deploying appliances such as wireless Access Points, IP cameras and VoIP phones in your network, even in mix-vendor environments. For added flexibility and power-saving, the DES-1210-08P integrates the new Time-Based PoE feature, which turns off the power when it is not needed, for example, at nights or during the weekends. This means that PoE-powered devices which otherwise would be always on, can be switched off centrally, saving power and money.
  • Extensive set of features
    Equipped with a complete line-up of features, these switches include Quality of Service, port trunking, Spanning Tree and IGMP snooping. Network monitoring and maintenance features include port mirroring, loopback detection and the innovative cable diagnostics. With cable diagnostics, the switch will flag a faulty Ethernet cable connected to any of its ports, detailing the type of error detected.
  • Secure your network
    The DES-1210 series support RADIUS authentication, to ensure that only authorized users are able to log into the network. In addition, the Access Control List (ACL) feature further enhances security by ensuring that network resources are accessible only by their legitimate users.
  • Avoid network disruption
    D-Link's innovative safeguard engine protects aginst traffic flooding caused by broadcast storms or virus attacks, blocking traffic that reaches the definable threshold and avoiding network lock-ups before they occur. Spanning Tree (STP) and Rapid Spanning Tree (RSTP) allow for redundant paths in a network to ensure servers and other resources are always available.
  • Versatile management
    The new generation of smart switches is provided with an intuitive PC-based smartConsole utility and a friendly web interface that enables administrators to configure and control their network down to the port level. The smartConsole automatically discovers multiple D-Link Web smart switches within the same network segment, so administrators can access all of them even before they have been configured. This allows for very quick deployments and initial setups. For more advanced administrators, the DES-1210 series supports a Command Line Interface (CLI) accessible with Telnet.
D-Link DES 1210 - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE)
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 1.6 Gbps , Forwarding performance (64-byte packet size): 1.19 Mpps
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, SNMP 3, CLI
Flow control, Layer 2 switching, DHCP support, auto-negotiation, BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Access Control List (ACL) support, Quality of Service (QoS), Cable Diagnostics Function, bandwidth control
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
19 cm x 12 cm x 3.8 cm
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
8 x 10/100 (PoE)
PoE
Performance
8K entries
Encryption Algorithm
SSL, SSL 3.0, SSL 2.0
RAM
348 KB
Flash Memory
16 MB
Status Indicators
Port transmission speed, power, link/activity
8 x 100Base-TX RJ-45 PoE
Internal power supply
MTBF
350,704 hours
FCC Class A certified, C-Tick, cUL, VCCI Class A ITE, IC
19 cm
12 cm
3.8 cm
10 - 95% (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
7GQZ D-Link DEM-311GT 1-Port Mini GBIC SX Multi Mode Fiber Transceiver In Stock £40.90
7GQZ C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
7GQZ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.22
7GQZ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.95
7GQZ C2G 2m Cat6a Shielded Patch - Blue In Stock £7.33
Type: Fast Ethernet
Ports: 8
Managed: Yes
POE: PoE
Brand: D-Link
Price Range Ex VAT: 100 - 150
