This RPS is equipped with an integrated detection circuit that continuously monitors the switching device's internal power supply. In the event of a power interruption, the redundant power supply is immediately triggered so that the LAN switch and its connected devices can continue providing service. This results in a more reliable network infrastructure and protects the network from a single failure of a network device power supply.
- D-Link DPS-200 - power supply - 60 Watt
- Power supply
- 0.8 kg
- Output Voltage
- 12 V
- Power Capacity
- 60 Watt
- 12.7 cm x 7.6 cm x 3.7 cm
- Designed For
- DES 3350SR, 3526, 3550; DGS 3100-24, 3100-24TG, 3312SR; xStack DES-3526, DES-3528, DES-3552, DES-3828, DXS-3350SR
- Power supply
- Input Voltage Range
- AC 100 - 240 V
- Input Voltage Range (Adjustable)
- AC 90 - 264 V
- Frequency Required
- 47 - 63 Hz
- Output Voltage
- 12 V
- Power Capacity
- 60 Watt
- FCC Class B certified, CSA, TUV, CISPR 22 Class B, cUL, EN 60950, EN55022, UL 60950
- 0 °C
- 50 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 80 °C
- 20 - 80%
- Humidity Range Storage
- 10 - 90%
- 12.7 cm
- 7.6 cm
- 3.7 cm
- 0.8 kg
- Designed For
- D-Link DES 3350SR, 3526, 3550 , D-Link DGS 3100-24, 3100-24TG, 3312SR , D-Link xStack DES-3526, DES-3528, DES-3552, DES-3828, DXS-3350SR
