D-Link's DGS-1100 Series provides an affordable solution for SOHOs and Small and Medium Businesses as well as enterprise deployment, such as in branch offices and meeting rooms that require simple network management. Enhanced management features, diagnostic and troubleshooting tools, and energy efficient technologies provide a flexible solution to suit your networking requirements.
- D-Link Smart Managed Switch DGS-1100-05PD - switch - 5 ports - smart
- Switch - 5 ports - smart
- Subtype
- Gigabit Ethernet
- Ports
- 2 x 10/100/1000 (PoE) + 3 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE
- Performance
- Switching capacity: 10 Gbps , Forwarding performance: 7.4 Mpps
- Capacity
- VLAN groups: 32 , IGMP groups: 32 , Queues per port: 4 , MAC address entries: 32
- MAC Address Table Size
- 2000 entries
- Jumbo Frame Support
- 9216 bytes
- Flow control, BOOTP support, IGMP snooping, port mirroring, Quality of Service (QoS), Cable Diagnostics Function, bandwidth control, IPv4 support, fanless, DHCP client, tagged VLAN, PoE Budget: 18 W (802.3at input power) / 8 W (802.3af input power)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3q
- 15 cm x 9.7 cm x 2.8 cm
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- Performance
- Capacity
- 2000 entries
- 9216 bytes
- Flash Memory
- 2 MB
- 2 x Gigabit LAN RJ-45 PoE - 15.4 W , 2 x Gigabit LAN RJ-45 , 1 x Gigabit LAN RJ-45 PoE input
- Power Device
- Power injector
- PoE powered
- 15 cm
- 9.7 cm
- 2.8 cm
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
