Your basket is empty
D-Link 48-PORT 10/100 SMART SWITCH
Quicklinx: 75GZWS00 Mfr#: DES-1210-52
The DES-1210 08P/28/28P/52 Fast Ethernet Smart Switches are the ideal choice for new deployments or network upgrades that require ease of use and advanced features at an affordable price. It enables businesses without highly trained IT staff to deploy, configure and maintain an enterprise class network.
D-Link DES 1210 - switch - 48 ports - Managed
Switch - 48 ports - Managed
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
48 x 10/100 + 2 x combo Gigabit SFP + 2 x 10/100/1000
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP
Flow control, Layer 2 switching, DHCP support, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, IP address filtering, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, SNTP support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), static IP mode, Safeguard Engine
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
44.1 cm x 25 cm x 4.4 cm
3.3 kg
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
8K entries
Encryption Algorithm
SSL, SSL 3.0, SSL 2.0
RAM
1 MB
Status Indicators
Port transmission speed, power, link OK, link/activity
48 x 100Base-TX RJ-45 , 4 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC)
Internal power supply
Rack Mounting Kit
Included
FCC Class A certified, C-Tick, cUL, VCCI Class A ITE
Software Included
Drivers & Utilities
44.1 cm
25 cm
4.4 cm
3.3 kg
10 - 95%
75GZ D-Link DEM-311GT 1-Port Mini GBIC SX Multi Mode Fiber Transceiver In Stock £40.55
75GZ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.07
75GZ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.55
75GZ C2G 2m Cat6a Shielded Patch - Blue In Stock £6.44
75GZ C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £40.80
