Your basket is empty
D-Link 48-port 10/100 PoE Layer 2 Managed Switch
Quicklinx: 988TWS00 Mfr#: DES-3200-52P
The DES-3200 Series is a member of D-Link's Layer 2 managed switch family designed for the ETTX, FTTX, and enterprise markets. The DES-3200 Series provides 8/16/24, or 48 10/100 Mbps Fast Ethernet connections and various SFP or combo Gigabit/SFP ports uplink, as well as PoE options.
D-Link xStack DES-3200-52P - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
48 x 10/100 (PoE) + 2 x SFP + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 17.6 Gbps , Forwarding performance (64-byte packet size): 13.1 Mpps
Virtual interfaces (VLANs): 4000
MAC Address Table Size
16K entries
Jumbo Frame Support
12KB
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, SSH-2, CLI
Flow control, Layer 2 switching, DHCP support, power over Ethernet (PoE), BOOTP support, ARP support, trunking, VLAN support, IGMP snooping, Syslog support, traffic shaping, DoS attack prevention, port mirroring, manageable, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, tunnelling, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, Safeguard Engine
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ag, IEEE 802.3at
44.1 cm x 30.8 cm x 4.4 cm
6 kg
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE
Performance
16K entries
Jumbo Frame Support
12KB
Max Units In A Stack
32
Encryption Algorithm
SSL, SSL 3.0, SSL 2.0
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
128 MB DDR2 SDRAM
Flash Memory
32 MB
Status Indicators
Port transmission speed, power, link/activity, console
48 x 100Base-TX RJ-45 PoE , 2 x 1000Base-T RJ-45 , 1 x console - RJ-45 , 4 x SFP (mini-GBIC)
Internal power supply
471.6 Watt
FCC Class A certified, UL, cUL, VCCI Class A ITE, CB, IC
44.1 cm
30.8 cm
4.4 cm
6 kg
-5 °C
50 °C
10 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
988T C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.07
988T C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.55
988T C2G 2m Cat6a Shielded Patch - Blue In Stock £6.44
988T C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £40.80
