Your basket is empty
D-Link 48-port 10/100/1G Smart Switch +4 RJ45/SFP
Quicklinx: 6ZYQWS00 Mfr#: DGS-1210-48
Type: Gigabit Ethernet
Ports: 48
Data Transfer Rate: 1Gbps
Managed: Yes
£234.23 ex VAT
£281.07 inc VAT
Express delivery Delivered on Tuesday
The DGS-1210 Series Gigabit Smart Managed Switches with Fibre Uplinks is the latest generation of D-Link Smart Managed Switches featuring high port density and optional PoE support. With D-Link Green 3.0 technology, the series offers a high level of energy saving and efficiency, as well as compliance with IEEE 802.3az Energy Efficient Ethernet standard.
D-Link Web Smart DGS-1210-48 - switch - 48 ports - Managed - desktop
Switch - 48 ports - Managed
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x shared SFP
MAC Address Table Size
16K entries
Jumbo Frame Support
13000 bytes
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, HTTP, TFTP
Flow control, Layer 2 switching, DHCP support, auto-negotiation, BOOTP support, RARP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, Safeguard Engine, D-Link Green Technology
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3az
44 cm x 20.7 cm x 4.4 cm
2.3 kg
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
16K entries
Jumbo Frame Support
13000 bytes
Authentication Method
RADIUS
RAM
1 MB
Built-in Devices
Led panel
Status Indicators
Link activity, port transmission speed, power, link OK
48 x 1000Base-T - RJ-45 , 4 x SFP (mini-GBIC)
Internal power supply
33.4 Watt
MTBF
322,402 hours
FCC Class A certified, C-Tick, cUL, VCCI Class A ITE, IC Class A
44 cm
20.7 cm
4.4 cm
2.3 kg
50 °C
10 - 95%
Ports: 48
Managed: Yes
Brand: D-Link
Price Range Ex VAT: 150 - 300
