Your basket is empty
D-Link 24-port 1000BaseT L2+ Wireless PoE Managed Switch
Quicklinx: 9888WS00 Mfr#: DWS-4026
The DWS-4026 is D-Link's next generation Unified Wired/Wireless Gigabit Switch with an array of advanced features and 802.11n support. With the ability to manage up to 64 unified wireless access points by itself and up to 256 unified wireless access points in a switch cluster, the DWS-4026 is a full-featured and cost-effective mobility solution for mid-to large enterprises and service providers
D-Link DWS-4026 L2+ Unified Wired/Wireless Gigabit Switch - switch - 24 ports - Managed
Switch - 24 ports - Managed
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE) + 4 x shared SFP
Power Over Ethernet (PoE)
PoE
MAC Address Table Size
8K entries
Routing Protocol
RIP-1, RIP-2, VRRP, static IP routing
Remote Management Protocol
SNMP 1, RMON 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH-2
Flow control, full duplex capability, Layer 2 switching, DHCP support, BOOTP support, ARP support, VLAN support, IGMP snooping, Syslog support, traffic shaping, DoS attack prevention, port mirroring, MAC address filtering, Broadcast Storm Control, Wireless Distribution System (WDS) support, SNTP support, tunnelling, WLAN controller mode, Wireless Intrusion Detection System (WIDS), Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Jumbo Frames support, DHCP server
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP)
44 cm x 38.9 cm x 4.4 cm
6 kg
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
PoE
8K entries
Routing Protocol
Encryption Algorithm
MD5, 128-bit WEP, 64-bit WEP, 152-bit WEP, TLS 1.0, SSL 3.0, PEAP, TTLS, TKIP, WPA2, WPA-PSK, AES-CCMP, WPA2-PSK, WPA2-Enterprise
Authentication Method
Secure Shell (SSH), RADIUS, Radio Service Set ID (SSID), TACACS+, Secure Shell v.2 (SSH2), MS-CHAP v.2, Extensible Authentication Protocol (EAP)
Status Indicators
Port status, port transmission speed, power, link OK, RPS (Redundant Power Supply), link/activity
24 x 1000Base-T RJ-45 PoE , 1 x console DB-9 management , 4 x SFP (mini-GBIC)
Expansion Slots
2 (total) / 2 (free) x Expansion Slot
Internal power supply
Redundant Power System (RPS) connector
MTBF
185,540 hours
FCC Class A certified, UL, VCCI, C-Tick, cUL, ICES-003, CB, EN 60601-1-2
44 cm
38.9 cm
4.4 cm
6 kg
10 - 90%
9888 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.07
9888 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.55
9888 C2G 2m Cat6a Shielded Patch - Blue In Stock £6.44
9888 C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £40.80
