Product
Brand
D-Link 24-PORT 10/100 SMART SWITCH
Clearance!
Clearance
Last Few Remaining
Limited Time Offer
Quicklinx: 75GYWS00 Mfr#: DES-1210-28
The DES-1210-28 is part of D-Link's third generation of Web Smart Switches that integrates advanced management and security functions for performance and scalability. While easy to use, the DES-1210-28 provides a complete and affordable solution for small and medium businesses (SMB). It includes an innovative fanless design in a 19" metal case.
D-Link DES 1210 - switch - 24 ports - Managed
Switch - 24 ports - Managed
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
24 x 10/100 + 2 x combo Gigabit SFP + 2 x 10/100/1000
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP
Flow control, Layer 2 switching, DHCP support, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, IP address filtering, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, SNTP support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), static IP mode, Safeguard Engine
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
44 cm x 21 cm x 4.4 cm
2.6 kg
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
8K entries
Encryption Algorithm
SSL, SSL 3.0, SSL 2.0
RAM
512 KB
Status Indicators
Port transmission speed, power, link OK, link/activity
24 x 100Base-TX RJ-45 , 4 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC)
Internal power supply
Rack Mounting Kit
Included
FCC Class A certified, C-Tick, cUL, VCCI Class A ITE
Software Included
Drivers & Utilities
44 cm
21 cm
4.4 cm
2.6 kg
10 - 95%
75GY D-Link DEM-311GT 1-Port Mini GBIC SX Multi Mode Fiber Transceiver In Stock £31.99
75GY C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.12
75GY C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.98
75GY C2G 2m Cat6a Shielded Patch - Blue In Stock £6.76
75GY C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £43.00
