D-Link 24-port 10/100/1G Smart Switch +4 RJ45/SFP
Installation required? Contact us today!
Quicklinx: 6ZYPWS00 Mfr#: DGS-1210-24
Type: Gigabit Ethernet
Ports: 24
Data Transfer Rate: 1Gbps
Managed: Yes
POE: [N/A]
11 in stock
£104.01 ex VAT
£124.81 inc VAT
The DGS-1210 Series Gigabit Smart Managed Switches with Fibre Uplinks is the latest generation of D-Link Smart Managed Switches featuring high port density and optional PoE support. With D-Link Green 3.0 technology, the series offers a high level of energy saving and efficiency, as well as compliance with IEEE 802.3az Energy Efficient Ethernet standard.
  • D-Link green
    D-Link is constantly striving to take the lead in developing innovative technology that allows for power-saving while not sacrificing operational performance or functionality. Power saving by link status helps to further save energy by automatically switching ports without a link to sleep mode and thus drastically reducing power consumption. The DGS-1210 series takes the approach to green IT and power saving one step further by incorporating a special chipset with Silicon technology.
  • Seamless integration
    The DGS-1210 series comes with Ethernet and Gigabit copper ports capable of connecting to existing Cat.5 twisted-pair cables. Additionally, the four ports of the DGS-1210 series combine SFP and copper connectivity into one port and therefore provide a more flexible solution for upstream or downstream server connections via fiber interface. Using the default presets, the administrator can quickly set up the switch without worrying about reconfiguring any settings and providing easy access for the user.
  • Extensive layer 2 features
    Equipped with a complete lineup of L2 features, these switches include IGMP snooping, port mirroring, spanning tree and Link Aggregation Control Protocol (LACP). The IEEE 802.3x flow control function allows servers to directly connect to the switch for fast, reliable data transfer. At 2000Mbps full duplex, the gigabit ports provide high-speed data pipes to servers with minimum data transfer loss. Network maintenance features include Loopback detection and cable diagnostics. Loopback detection is used to detect loops created by a specific port and automatically shut down the affected port. Cable diagnostics is designed for network administrators to quickly examine the quality of the copper cables and also determine the type of cable error.
  • QoS, bandwidth control
    The switches are perfect for deployment in a VoIP environment, as they support Auto Voice VLAN and Differentiated Services Code Point (DSCP) QoS for VoIP application. Auto Voice VLAN will automatically place voice traffic from an IP phone to an assigned VLAN and by doing so enhance the VoIP service. With a higher priority and individual VLAN, this feature guarantees the quality and security of VoIP traffic. DSCP marks parts of an IP packet, enabling different levels of service to be assigned for network traffic. With Bandwidth Control, the network administrator can reserve bandwidth for important functions that require a larger bandwidth or might have high priority.
  • Secure your network
    D-Link's innovative safeguard engine function protects the switches against traffic flooding caused by virus attacks. The switches also support 802.1X port-based authentication, allowing the network to be authenticated through external RADIUS servers. In addition, the Access Control List (ACL) feature enhances network security and helps to protect the internal IT network. The DGS-1210 series includes ARP spoofing prevention, which protects from attacks on the Ethernet network that may allow an intruder to sniff data frames on a LAN, modify traffic, or bring traffic to a halt altogether by sending fake ARP messages to the network. To prevent ARP spoofing attacks, the switch uses packet control ACLs to block invalid packets that contain fake ARP messages. For added security, the DHCP Server Screening feature screens rogue DHCP server packets from user ports to prevent unauthorized IP assignment.
D-Link Web Smart DGS-1210-24 - switch - 24 ports - Managed
Switch - 24 ports - Managed
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x shared SFP
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, HTTP, TFTP
Flow control, full duplex capability, Layer 2 switching, DHCP support, auto-negotiation, BOOTP support, RARP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, Safeguard Engine
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
44 cm x 21 cm x 4.4 cm
3 kg
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
8K entries
Authentication Method
RADIUS
RAM
512 KB
Built-in Devices
Led panel
Status Indicators
Port transmission speed, power, link OK, link/activity
24 x 1000Base-T RJ-45 , 4 x SFP (mini-GBIC)
Internal power supply
24.1 Watt
MTBF
410,948 hours
FCC Class A certified, C-Tick, cUL, VCCI Class A ITE, IC Class A
44 cm
21 cm
4.4 cm
3 kg
10 - 95%
Ports: 24
Managed: Yes
POE: [N/A]
Brand: D-Link
Price Range Ex VAT: 100 - 150
