D-Link 24-Port 10/100/1000 EasySmart Switch
Quicklinx: 7YQ2WS00 Mfr#: DGS-1100-24
Type: Gigabit Ethernet
Ports: 24
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
Hurry, only 2 left in stock!
£90.94 ex VAT
£109.12 inc VAT
D-Link's DGS-1100 Series provide an affordable solution for SOHOs and Small and Medium Businesses as well as enterprise deployment, such as in branch offices and meeting rooms that require simple network management. Most models comes in a compact desktop-sized metal case and features a wide selection of Gigabit port configurations with optional Gigabit fiber uplink ports. There are 4 switches in the series supporting Power-over-Ethernet with 2 of the switches in the offering high-power-budget PoE for businesses looking to power VoIP phones, wireless access points or network cameras.
  • Resilience and performance
    The basic lineup of L2 features in the EasySmart series makes them very suitable for SMB with small IT teams, without sacrificing on performance and security. Network downtime is reduced drastically with loopback detection and broadcast storm control. Security and confidentiality of network traffic is guaranteed with VLANs. Ample bandwidth on the uplinks to the rest of the network can be achieved with link aggregation, and the cable diagnostics function provides an easy and convenient way to quickly detect and troubleshoot cabling problems.
  • Versatile management
    The EasySmart series can be easily configured through an intuitive, password-protected web-based interface. The web interface allows network administrators to remotely control and monitor the switch down to the port level.
D-Link EasySmart Switch DGS-1100-24 - switch - 24 ports - Managed
Switch - 24 ports - Managed
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Performance
Switching capacity: 48 Gbps , Forwarding performance (full duplex): 35.7 Mpps
MAC Address Table Size
8K entries
Remote Management Protocol
HTTP
Flow control, Layer 2 switching, DHCP support, trunking, VLAN support, IGMP snooping, port mirroring, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Quality of Service (QoS), bandwidth control
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000
Performance
8K entries
HTTP
RAM
2 MB
Status Indicators
Port transmission speed, power, link/activity
24 x 1000Base-T RJ-45
Internal power supply
FCC Class A certified, cUL, VCCI Class A ITE
10 - 95%
Min Storage Temperature
-10 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95%
7YQ2 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
7YQ2 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.22
7YQ2 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.89
7YQ2 C2G 2m Cat6a Shielded Patch - Blue In Stock £7.31
Ports: 24
Managed: Yes
POE: No
Brand: D-Link
Price Range Ex VAT: 50 - 100
