D-Link 20 10/100/1000 Base-T port Unified Switch
Quicklinx: 9883WS00 Mfr#: DWS-3160-24TC
The DWS-3160 Series is D-Link's latest unified wired/wireless Gigabit Layer 2+ managed switch. Designed to be the ideal mobility solution for medium-sized and large enterprises and service providers, the DWS-3160 empowers administrators to exercise total control over their wireless networks by centralizing all aspects of provisioning and management.
  • Simplified management
    The DWS-3160 is able to centralize all critical WLAN management, thereby eliminating the need to manage access points individually. The administrator simply assigns a profile to an individual D-Link Unified Access Point, and the configuration corresponding to that profile would be applied onto that access point automatically.
  • Trusted security
    The DWS-3160 offers a state-of-the-art Wireless Intrusion Detection System (WIDS), which empowers administrators to detect Rogue Access Points and Rogue Clients, effectively preventing them from causing damage to the network. The administrator can also activate various threat detections and use Radio Frequency Scan to sweep the entire wireless network to identify any possible security breach in advance.
  • Network resiliency
    When a number of access points are deployed close to each other, interference may result if proper RF management is not implemented. The DWS-3160 is aware of how the radio spectrum is being utilized in the network and will automatically assign the most optimized channel to each access point under its management. This greatly reduces RF interference and will allow the administrator to deploy APs more densely.
  • Seamless mobility
    Wireless clients can enjoy seamless and uninterrupted roaming from AP to AP if they are managed by the same DWS-3160, even if they are not in the same subnet. Because the DWS-3160 employs various mechanisms such as pre-authentication and keycaching, wireless users can freely roam the entire network without needing to re-authenticate. This allows tablet and smart phone and netbook computer users to travel freely within any premise covered by the DWS-3160's managed APs without having to worry about network connectivity, thus enabling for a truly mobile workplace.
D-Link DWS 3160 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
20 x 10/100/1000 + 4 x combo Gigabit SFP
Performance
Switching capacity: 48 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
Routing Protocol
RIP, static IP routing
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, TFTP, SSH, CLI
BOOTP support, VLAN support, IGMP snooping, port mirroring, IPv6 support, sFlow, STP support, RSTP support, VRRP support, MSTP support, QoS, DHCP server, MLD snooping, NAP, bandwidth control, LLDP support, DHCP relay, LACP, Traffic Control, DHCP client, GVRP
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP)
44 cm x 21 cm x 4.4 cm
2.6 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
8K entries
Jumbo Frame Support
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
20 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 4 x SFP (mini-GBIC) , 1 x management RJ-45
Internal power supply
MTBF
561,829 hours
FCC Class A certified, UL, VCCI, C-Tick, cUL, ICES-003, CB
44 cm
21 cm
4.4 cm
2.6 kg
50 °C
10 - 90%
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90%
