The DCS-6010L Wireless N 360° Home Network Camera is a mydlink-enabled IP surveillance camera built with a fisheye lens and a 2 megapixel sensor, making it ideal for monitoring large areas with a single camera.
The DCS-6010L uses a fisheye lens to provide incredible wide angle coverage; simply place it on a wall for a panoramic 180° view of a room, or place it on a ceiling for a full 360° view without blind spots. Distortion correction fixes the camera video so you can use ePTZ to zoom in, zoom out, and pan across your camera's video and survey a large area easily.
The Wireless N 360° Home Network Camera is mydlink-enabled, which means that you can access and configure your camera remotely, no matter where you are. See your camera's live view through the mydlink website, or download the mydlink mobile app and view your camera directly on your iOS or Android mobile device. Keep an eye on your home while you're at work, or check on the office when you're out on the road; mydlink makes it all possible.
The DCS-6010L is a self-sufficient surveillance solution, capable of recording snapshots and video to a MicroSD card without requiring a PC or network storage device. If you want to expand your surveillance options, D-ViewCam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features, including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities.
360-degree surveillance
The DCS-6010L uses a fisheye lens to provide incredible wide angle coverage; simply place it on a wall for a panoramic 180° view of a room, or place it on a ceiling for a full 360° view without blind spots. Distortion correction fixes the camera video so you can use ePTZ to zoom in, zoom out, and pan across your camera's video and survey a large area easily. -
Anywhere access with mydlink
The Wireless N 360° Home Network Camera is mydlink-enabled, which means that you can access and configure your camera remotely, no matter where you are. See your camera's live view through the mydlink website, or download the mydlink mobile app and view your camera directly on your iOS or Android mobile device. Keep an eye on your home while you're at work, or check on the office when you're out on the road; mydlink makes it all possible. -
Zero configuration
If you have a mydlink-enabled cloud router, setting up and configuring your DCS-6010L is a snap, thanks to mydlink zero configuration. Simply connect your camera to its power adapter and then connect your camera to your cloud router with an Ethernet cable - the camera will automatically be added to your account. mydlink does the hard work for you, allowing even novice users to set up and use their mydlink-enabled cameras immediately. -
A complete, expandable surveillance solution
The DCS-6010L is a self-sufficient surveillance solution, capable of recording snapshots and video to a MicroSD card without requiring a PC or network storage device. If you want to expand your surveillance options, D-ViewCam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features, including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities. -
Built for versatility
The DCS-6010L comes with a wealth of features that enhance its surveillance capabilities, making it ideal for any situation. A built-in microphone and speaker allow for 2-way communication or broadcasting of an alarm siren during an event. It even includes 802.11n wireless connectivity, allowing it to be placed anywhere easily without requiring cabling to be installed.
- D-Link DCS 6010L Wireless N 360° Home Network Camera - network surveillance camera - dome
- Network surveillance camera - fixed - dome
- Audio
- Yes: built-in speaker, built-in microphone
- 13.42 cm x 13.42 cm x 4.98 cm
- 267 g
- Connectivity Technology
- Wired, wireless
- Camera
- Max Resolution
- 1600 x 1200
- Optical Sensor Type
- CMOS - 1/3.2"
- Minimum Illumination
- F2.0
- Focal Length
- 1.25 mm
- Lens Iris
- F/2.0
- Ethernet 10Base-T/100Base-TX, IEEE 802.11n
- Voltage
- DC 5 V
- Motion sensor, sharpness control, progressive scanning, saturation control, brightness control, contrast control, ONVIF support, microSDHC card slot, distortion control
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Form Factor
- Dome
- Wired, wireless
- 13.42 cm
- 13.42 cm
- 4.98 cm
- 267 g
- Localisation
- United Kingdom
Camera
- Colour - fixed
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 1600 x 1200
- Digital Zoom
- 10
- F2.0
- Supported Image Formats
- JPEG
Image Sensor
- CMOS 1/3.2"
Lens Construction
- Focal Length
- 1.25 mm
- Lens Iris
- F/2.0
- Horizontal Field of View (degree)
- 180
- Vertical Field of View (degree)
- 180
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, PPPoE, IGMP, Samba, QOS, CoS
- 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
- C-Tick, IC, FCC
- Power Requirements
- DC 5 V
- Power Device
- Power adapter - external AC 120/230 V (50/60 Hz) 3.9 Watt
- OS Required
- Microsoft Windows Vista / XP / 7
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
