D-Link 16P switch 14x10G SFP+/2x 10GBase-T/SFP+
Quicklinx: D0X1WS00 Mfr#: DXS-1100-16SC
The DXS-1100 Series 10 Gigabit Ethernet Smart Managed Switches are a set of Smart Layer 2 10 Gb Ethernet switches that provide an entry-level solution for Small and Medium Businesses (SMB) wishing to deploy 10 Gb Ethernet. These switches are ideal for server farms or as network aggregation devices, and provide a cost-effective and feature-rich solution to 10 Gb Ethernet requirements. The DGS-1100-16SC consists of 14 x 10G SFP+ ports and 2 x 10GBASE-T/SFP+ combo ports.
D-Link DXS 1100-16SC - switch - 16 ports - smart - rack-mountable
Switch - 16 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
14 x SFP+ + 2 x 10 Gigabit SFP+
Performance
Switching capacity: 320 Gbps , Forwarding performance: 238.096 Mpps , Packet buffer size: 2 Mbps
VLAN groups: 128
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, SNMP 3, SNMP 2c, HTTP, TFTP
Flow control, MDI/MDI-X switch, BOOTP support, ARP support, IGMP snooping, DoS attack prevention, port mirroring, WRR queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, STP support, RSTP support, DHCP snooping, Jumbo Frames support, MLD snooping, Safeguard Engine, D-Link Green Technology, LLDP support, DHCP relay, Port Security, SNMP trap, DHCP client, Loopback, DSCP support
IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.3an, IEEE 802.3az, IEEE 802.1AX
44 cm x 25 cm x 4.4 cm
2.91 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
VLAN groups: 128
16K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SSL, SSL 3.0, SSL 2.0
Flash Memory
128 MB
Status Indicators
Port transmission speed, power, link/activity, fan
2 x 10GBase-T SFP+ , 14 x Gigabit LAN SFP+
Internal power supply
60 Watt
MTBF
254,038 hours
VCCI, BSMI, cUL, CB, CCC, FCC, RoHS, RCM
44 cm
25 cm
4.4 cm
2.91 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
D0X1 D-Link DEM-311GT 1-Port Mini GBIC SX Multi Mode Fiber Transceiver In Stock £23.38
D0X1 D-Link SFP+ Direct Attach Stacking Cable, 1M In Stock £165.07
D0X1 D-Link 1-Port Mini GBIC Module for 1000BaseLX (LC Duplex) In Stock £31.86
