The D-Link DMC-1000 chassis provides 16 slots for installation of up to 16 media converters. You can start with single media converters, each equipped with its own metal case housing and AC power adapter. When your requirements grow, you can mount a chassis in your equipment rack and install your media converters in the chassis. The media converter cases can be easily removed, and the media converter PC boards can be slid into the chassis slots.
The chassis lets you install multiple media converters in an equipment rack together with the network devices for which they provide media conversion. This provides for space saving, and the cabling will look neat. The chassis comes with its own universal AC to DC power supply. For maximum power availability, an optional redundant power supply is available for installation in chassis.
- D-Link DMC 1000 - modular expansion base
- Modular expansion base
- Form Factor
- External - rack-mountable
- Power
- AC 100/240 V
- Form Factor
- Rack-mountable - external
- Installed Modules Qty (Max)
- 0 (16)
- Built-in Devices
- Led panel
- Status Indicators
- Power
- Expansion Slots
- 16 (total) / 16 (free) x Expansion Slot
- FCC Class A certified
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- AC 100/240 V (50/60 Hz)
- UL
