D-Link 16-PORT 10/100 EASYSMART SWITC
Quicklinx: 7GQXWS00 Mfr#: DES-1100-16
Type: Fast Ethernet
Ports: 16
Data Transfer Rate: 100Mbps
Managed: No
POE: No
£43.14 ex VAT
£51.76 inc VAT
The DES-1100 Series Fast Ethernet Smart Managed Switch features a full set of configurable functions that provide strong performance and scalability. With an easy-to-use management interface accessible via a PC utility or web browser, the DES-1100 Series helps customers to quickly and easily deploy their network.
  • Resilience/performance enhancement
    Equipped with a complete lineup of L2 features, these switches include IGMP Snooping and Port Mirroring. Network maintenance features include Loopback Detection and Cable Diagnostics. Loopback Detection is used to detect loops created by a specific port and automatically shuts down the affected port. Cable Diagnostics is designed for network administrators to quickly examine the quality of the copper cables and also determine the type of cable error.
  • Versatile management
    The EasySmart Switches supports an intuitive SmartConsole utility and a web based management interface that enables administrators to remotely control their network down to the port level. The SmartConsole easily allows customers to discover multiple D-Link EasySmart switches within the same L2 network segment. With this utility, users do not need to change the IP address of their PC and it also provides an easy initial setting of the Smart switches.
D-Link EasySmart Switch DES-1100-16 - switch - 16 ports - unmanaged
Switch - 16 ports - unmanaged
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
16 x 10/100
MAC Address Table Size
8K entries
Flow control, auto-negotiation, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, Quality of Service (QoS), bandwidth control
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x
28 cm x 12.5 cm x 4.4 cm
227 g
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
16 x 10/100
8K entries
Flash Memory
1 MB
Status Indicators
Port transmission speed, power, link OK, link/activity
16 x 100Base-TX RJ-45
Internal power supply
5.96 Watt
Mounting Kit
Included
MTBF
597,779 hours
FCC Class A certified, UL, C-Tick, cUL, VCCI Class A ITE, IC
28 cm
12.5 cm
4.4 cm
227 g
10 - 95%
7GQX C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
7GQX C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.18
7GQX C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.51
Type: Fast Ethernet
Ports: 16
Managed: No
POE: No
Brand: D-Link
Price Range Ex VAT: 0 - 50
