D-Link 10 Port switch including 8x10G ports & 2xSFP
Quicklinx: D0X0WS00 Mfr#: DXS-1100-10TS
Type: Gigabit Ethernet
Ports: 8
Managed: Yes
Hurry, only 3 left in stock!
£561.32 ex VAT
£673.58 inc VAT
The DXS-1100-10TS 10-Port 10 Gigabit Ethernet Smart Switch provides an entry-level solution for Small and Medium Businesses wishing to deploy 10 Gb Ethernet. 8 x 10 GBase-T ports instantly increases network bandwidth over standard Cat 6a cabling without the need to overhaul existing network infrastructure wiring. 2 x 10 Gigabit SFP+ fiber ports provide additional network connection flexibility.
  • Energy saving
    The DXS-1100-10TS incorporates D-Link Green technology for increased energy efficiency. Smart fans and temperature sensors ensure that the fans are running at the optimum speed to cool the system. If the environment temperature is suitable and the switch is at low utilization, the smart fans reduce their speed, resulting in lower power consumption and noise output. The Link Status feature reduces power utilization by powering-down inactive ports and putting them into sleep mode. The DXS-1100-10TS also takes its Green credentials one step further by incorporating a chipset with advanced silicon technology for reduced power utilization.
  • Easy to deploy
    The DXS-1100-10TS supports an intuitive client-based utility (D-Link Network Assistant Utility) and a web-based management interface. The client-based utility allows customers to discover all switches in the D-Link Smart Switch family within the same L2 network segment. With this utility, users do not need to change the IP address of their PC, and this also makes initial setup of the Smart Switches quick and easy. Switches within the same L2 network segment that are connected to the user's PC are displayed on-screen for instant access. This allows for extensive switch configuration and basic setup of discovered devices, including password changes and firmware upgrades. The graphic web-based management interface provides a user-friendly interface that enables network administrators to remotely control their network down to the port level.
  • Auto surveillance VLAN and bandwidth control
    The DXS-1100-10TS supports Auto Surveillance VLAN (ASV), and Auto Voice VLAN, which are best suited for video surveillance and Voice over IP (VoIP) deployments, respectively. Auto Surveillance VLAN is a feature that automatically places video traffic from IP cameras to an assigned VLAN to enhance the IP surveillance service. With a higher priority and individual VLAN, the quality and the security of surveillance traffic are guaranteed. The Auto Surveillance VLAN function will check the source MAC address on the incoming packets. If it matches specified MAC address, the packets will pass through switch with desired priority. In a similar fashion, the Auto Voice VLAN technology enhances VoIP functionality by automatically placing voice traffic from an IP phone into an assigned VLAN. In addition, Bandwidth Control can reserve bandwidth on a per port basis for important functions that require larger bandwidth or might have high priority.
  • Advanced security features
    The DXS-1100-10TS is equipped with advanced security features such as Static MAC, Storm Control, and IGMP Snooping. Static MAC allows users to create a MAC whitelist for specific ports, helping administrators limit network access to authorized devices only. Storm Control monitors broadcast, multicast, or unknown unicast traffic and will start blocking or discarding packets which could flood the network when the defined threshold is exceeded. IGMP Snooping is able to reduce the loading of L3 multicast routers and save bandwidth in network throughput.
  • Easy troubleshooting
    The DXS-1100-10TS features Loopback Detection and Cable Diagnostics to help network administrators find and solve network problems quickly and easily. Loopback Detection is used to detect loops created by a specific port and automatically shuts down the affected port. Cable Diagnostics help network administrators quickly examine the quality of the copper cables, recognize the cable type, and detect cable errors.
D-Link DXS 1100-10TS - switch - 8 ports - smart - rack-mountable
Switch - 8 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10GBase-T + 2 x 10 Gigabit SFP+
Performance
Switching capacity: 200 Gbps
IGMP groups: 512 , Virtual interfaces (VLANs): 4094 , ARP entries: 128
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, SNMP 3, SNMP 2c, HTTP, TFTP
Flow control, MDI/MDI-X switch, BOOTP support, ARP support, IGMP snooping, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, DHCP snooping, Jumbo Frames support, MLD snooping, Safeguard Engine, D-Link Green Technology, LLDP support, DHCP relay, Port Security, SNMP trap, DHCP client, Loopback, DiffServ Code Point (DSCP) support
IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.3an, IEEE 802.3az, IEEE 802.1AX
AC 120/230 V (50 - 60 Hz)
44 cm x 21 cm x 4.4 cm
2.69 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SSL, SSL 3.0, SSL 2.0
Flash Memory
128 MB
Status Indicators
Port transmission speed, power, link/activity, fan
8 x 10GBase-T RJ-45 , 2 x 10Gbit LAN SFP+
Internal power supply
50.9 Watt
MTBF
585,959 hours
VCCI, BSMI, cUL, CB, CCC, FCC, RoHS, RCM
44 cm
21 cm
4.4 cm
2.69 kg
Limited warranty - lifetime
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 8
Managed: Yes
Brand: D-Link
Price Range Ex VAT: 500 - 750
