Designed to support distances up to 300 meters, the DEM-421XT is a high performance 850nm Multi-Mode XFP transceiver. Supporting Full-duplex, 10Gigabit speeds on Multi-Mode fiber cables, the DEM-421XT is 802.3ae 10GBASE-SR compliant and supports Full-duplex 802.3x Flow control. The DEM-421XT provides the necessary signal amplification for data to be transmitted to the network cable from the port, and vice versa.
The DEM-421XT is hot swappable. You can remove or replace the transceiver with the system powered on. This permits transceivers to be added or swapped without interrupting network systems.
- D-Link DEM 421XT - XFP transceiver module - 10 GigE
- XFP transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-SR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 10 GigE
- Max Transfer Distance
- 300 m
- Designed For
- D-Link DEM-420X; xStack DXS-3326GSR
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-SR
- 10 GigE
- 10 Gbps
- 850 nm
- 300 m
- Full duplex capability
- IEEE 802.3x, IEEE 802.3ae
- 1 x Ethernet 10GBase-SR - LC multi-mode x 2
- Compatible Slots
- 1 x XFP
- Designed For
- D-Link DEM-420X , D-Link xStack DXS-3326GSR
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.07 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.55 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £6.44 |
C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue | In Stock | £40.80 |
