The Online S series UPS is ideal for servers, networking equipment, workstations and other mission-critical applications which require pure sine ware power protection. Featuring online double conversion design and zero transfer time, it can provide consistent and seamless pure sine wave power to critical loads. With the add-on advantage of Extended Runtime (XL) battery packs, the UPS backup time can be extended to maximize workflow flexibility.
- CyberPower Smart App Online OLS1500E - UPS - 800 Watt - 1000 VA
- UPS - external
- 13.1 kg
- Output Voltage
- AC 208/220/230/240 V ± 3%
- Power Capacity
- 800 Watt / 1000 VA
- Input Connectors
- 1 x power IEC 60320 C20
- Output connectors
- 4 x power IEC 60320 C13 , 1 x terminal block
- Battery
- Lead Acid expandable - 7 Ah
- Battery Form Factor
- Internal
- Batteries Qty
- 3
- Run Time (Up To)
- 6 min at full load
- Networking
- RS-232, USB
- System Requirements
- Apple MacOS, Linux, Microsoft Windows 2000 Professional, Microsoft Windows 98/ME, Microsoft Windows Vista / XP / 7, Microsoft Windows 2003, Microsoft Windows Server 2008
- 15.1 cm x 39.4 cm x 22.5 cm
- 3-year warranty
- UPS - external
- Battery Enclosure Type
- Internal
- UPS Technology
- On-line
- Input Voltage Range
- AC 120 - 280 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 40 - 70 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 208/220/230/240 V ± 3% - 50/60 Hz
- Power Capacity
- Dataline Surge Protection
- Network/phone line - RJ-45/RJ-11
- Output Waveform
- Sinewave
- Surge Suppression
- Circuit Protection
- Circuit breaker
- Expandable
- Quantity
- 3
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- Capacity
- 7 Ah
- Run Time (Up To)
- 6 min at full load , 16 min at half load
- Recharge Time
- 5 hours
- Remote Management Interface
- RS-232, USB
- 1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off)
- Equipment Protection Value
- 100000 Euros
- Audible alarm, LCD display, built-in maintenance bypass, LED indicators, overload protection, cold-start function
- PCT, ISO 14001, RoHS, ISO 9001:2000
- Software Included
- PowerPanel Business Edition
- OS Required
- Limited warranty - batteries - 3 years
- 0 °C
- 40 °C
- 0 - 90%
- 15.1 cm
- 39.4 cm
- 22.5 cm
- 13.1 kg
- Shipping Width
- 24.1 cm
- Shipping Depth
- 51 cm
- Shipping Height
- 31.3 cm
- Shipping Weight
- 16.8 kg
