The Online Series UPS is ideal for servers, networking equipment, workstations and other mission-critical applications which require pure sineware power protection. Featuring online double conversion design and zero transfer time, it can provide consistent and seamless pure sinewave power to critical loads. With the add-on advantage of Extended Runtime (XL) battery packs, the UPS backup time can be extended to maximize workflow flexibility.
- CyberPower Smart App Online OL6000ERT3UD - UPS - 5.4 kW - 6000 VA
- UPS - external
- Rack Size
- 6U
- 100 kg
- Output Voltage
- AC 200/208/220/230/240 V ± 2%
- Power Capacity
- 5.4 kW / 6000 VA
- Input Connectors
- Hardwire 3-wire
- Output connectors
- 2 x power IEC 60320 C13 , 1 x power IEC 60320 C19 , 1 x hardwire 3-wire
- Battery
- Lead Acid - 7.2 Ah
- Battery Form Factor
- Plug-in module
- Batteries Qty
- 20
- Run Time (Up To)
- 5.3 min at full load
- Networking
- RS-232, USB
- System Requirements
- Apple MacOS, Linux, Microsoft Windows 2000 Professional, Microsoft Windows 98/ME, Microsoft Windows Vista / XP / 7, Microsoft Windows 2003, Microsoft Windows Server 2008
- 43.3 cm x 60 cm x 26.4 cm
- 3-year warranty
- UPS - external
- Battery Enclosure Type
- Plug-in module
- Height (Rack Units)
- 6U
- UPS Technology
- On-line
- Input Voltage Range
- AC 120 - 280 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 40 - 70 Hz
- Input Connectors
- Hardwire 3-wire
- Power Output Connectors Details
- Output Voltage
- AC 200/208/220/230/240 V ± 2% - 50/60 Hz
- Power Capacity
- 5.4 kW / 6000 VA
- Dataline Surge Protection
- Network/phone line - RJ-45/RJ-11
- Output Waveform
- Sinewave
- Surge Suppression
- Efficiency
- 95%
- Quantity
- 20
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- Capacity
- 7.2 Ah
- Run Time (Up To)
- 5.3 min at full load , 15.8 min at half load
- Recharge Time
- 4 hours
- Remote Management Interface
- RS-232, USB
- 1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off) , 1 x management
- Expansion Slots
- Expansion Slot
- Cables Included
- Power cable - external , Serial cable - external , USB cable - external , Phone cable - external
- Rack Mounting Kit
- Included
- Equipment Protection Value
- 100000 Euros
- Audible alarm, LCD display, LED indicators, overload protection, cold-start function, short-circuit protection, Eco-efficiency, temperature controlled fan, Smart Battery Management (SMB)
- C-Tick, IEC 61000-4-5, PCT, RoHS
- Software Included
- PowerPanel Business Edition
- OS Required
- Limited warranty - batteries - 3 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
- 43.3 cm
- 60 cm
- 26.4 cm
- 100 kg
