Cyberpower Smart App Online 1000VA RT2U UPS
Quicklinx: BBTVWS00 Mfr#: OL1000ERTXL2U
The Online OL1000ERTXL2U UPS with LCD readout and pure sine wave output safeguards mission-critical servers, telecom equipment, VoIP and internetworking hardware that requires seamless connection and advanced power protection. Its Double-Conversion topology is generator compatible and delivers consistent and having zero transfer time during power outages, protecting connected equipment and preventing costly business interruptions. This UPS is ENERGY STAR® qualified and the configurable Economy Mode Setting increases the UPS operating efficiency by up to 95% to save on energy costs by reducing energy consumption and waste heat generated. Smart Battery Management (SBM) charges batteries in several phases to reduce the deterioration of battery capacity hence improve battery life in the long run.
The LCD control panel provides 44 different settings for status and operation. Functions include menus for checking power status on (19) different parameters, (22) settings for setup, control and testing and (3) selections for event logging. With the optional DB26 cable, the LCD control panel can be removed from the UPS and relocated up to 10 feet away from the UPS for ease of use regardless of locations.
The OL1000ERTXL2U comes with a capacity of 1000VA/900Watts (0.9 high power factor) that can be configured for an output of 200V, 208V, 220V, 230V and 240V ± 2% for maximum flexibility under different application scenarios. It has eight (8) IEC C13 receptacles, including four (4) for critical loads management, and three (3) hot-swappable, user-replaceable 12V/9Ah batteries. The unit offers one (1) HID USB and one (1) Serial connectivity port with PC and one (1) Emergency Power Off (EPO) port for the capability to immediately power down entire installed equipment from a single access point. This model allows an addition of up to ten (10) BPE36V60ART2US external battery packs to increase the runtime of the unit. The battery packs are easy to plug-in and can be hot-swapped to maintain system uptime during normal UPS maintenance.
The OL1000ERTXL2U features remote network management capabilities which include the PowerPanel® Business Edition software, an optional SNMP/ HTTP remote management card, and an optional ENVIROSENSOR. These management tools enable administrators to perform various operations including remote management, real-time monitoring, UPS configuration, and scheduled server/workstations shutdowns. All Smart App UPS systems and Remote Management Card have achieved the status of Cisco EnergyWise certified, better supporting other EnergyWise-enabled entities and be easily monitored and controlled to achieve the best energy performance under the EnergyWise operation framework.
For as long as you own this product, CyberPower will cover up to $100,000 of properly connected equipment if it's ever damaged by a surge, including surges due to lightning strikes.
CyberPower Smart App Online OL1000ERTXL2U - UPS - 900 Watt - 1000 VA
UPS - external
Rack Size
2U
18 kg
Output Voltage
AC 200/208/220/230/240 V ± 2%
Power Capacity
900 Watt / 1000 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
8 x power IEC 60320 C13
Lead Acid - 7.2 Ah
Battery Form Factor
Plug-in module
Batteries Qty
3
Run Time (Up To)
4 min at full load
RS-232, USB
Apple MacOS, Linux, Microsoft Windows 2000 Professional, Microsoft Windows 98/ME, Microsoft Windows Vista / XP / 7, Microsoft Windows 2003, Microsoft Windows Server 2008
43.3 cm x 43 cm x 8.8 cm
3-year warranty
UPS - external
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
UPS Technology
On-line
Input Voltage Range
AC 120 - 280 V
Frequency Provided
50/60 Hz
Frequency Required
40 - 70 Hz
Input Connectors
Output Voltage
AC 200/208/220/230/240 V ± 2% - 50/60 Hz
Power Capacity
900 Watt / 1000 VA
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11
Output Waveform
Sinewave
Surge Suppression
Efficiency
93%
Quantity
3
Lead Acid
Voltage Provided
12 V
7.2 Ah
Run Time (Up To)
4 min at full load , 11 min at half load
Recharge Time
4 hours
Remote Management Interface
RS-232, USB
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Equipment Protection Value
100000 Euros
Audible alarm, LCD display, LED indicators, overload protection, cold-start function, short-circuit protection, Eco-efficiency, temperature controlled fan, Smart Battery Management (SMB)
IEC 61000-4-5, PCT, RoHS
Software Included
PowerPanel Business Edition
Limited warranty - batteries - 3 years
43.3 cm
43 cm
8.8 cm
18 kg
