Your basket is empty
CyberPower RMCARD305 Remote Management Adapter
Quicklinx: C1CZWS00 Mfr#: RMCARD305
The CyberPower RMCARD305 is a full-featured network UPS management device that remotely manages, monitors, and controls CyberPower OL Series UPS system. The internal card allows remote monitoring and control via Web Browser or NMS connection. By utilizing the PowerPanel Business Edition Client auto-shutdown software, servers and workstations stay protected from data loss due to power failure. An optional environmental sensor (ENVIROSENSOR) can be added to monitor ambient temperature and humidity. Event logging tracks UPS events and input/output status records. Automated event notifications via email, SMS text, SNMP traps, and Syslog server can be setup to insure real time status of changes. Firmware can be updated by users to insure you have the latest features and updates. MD5 security management is also provided to protect the integrity of the network. Secure emails are delivered using either SSL or TLS. User log in accounts can be secured through either: RADIUS, LDAP, LDAPS, or Windows Active Directory authentication protocols.
CyberPower RMCARD305 - remote management adapter
Remote management adapter
Plug-in module
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Network / Transport Protocol
NTP, SMTP, FTP, DHCP, DNS
Smart App Online OL6000RT3UTF
Plug-in module
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, HTTP, HTTPS, SSH
Status Indicators
Link OK, transmit, receive
LDAP support, Syslog support, IPv6 support, firmware upgradable, RADIUS support, SMS alert, IPv4 support, SNMP trap, e-mail notification
Encryption Algorithm
SSL, TLS
CyberPower Smart App Online OL6000RT3UTF
