The Professional Tower Series UPS provides advanced level of power protection to servers, telecom equipment, VOIP, Internet working hardware and other mission-critical applications. Featuring Pure Sinewave output and Automatic Voltage Regulation (AVR) stabilizing the AC signal and maintaining a safe voltage, it allows the UPS to maintain safe power levels for the connected equipment without resorting to battery power. The multifunction LCD readout provides immediate access to precise information of critical power/battery condition and to help users control and manage the machine easily.
Emergency Power Off (EPO) port
CyberPower UPS system with Emergency Power Off (EPO) port present the capability to immediately power down entire installed equipment from a single access point by activating a push button.
- CyberPower Professional Tower Series PR2200ELCDSL - UPS - 1980 Watt - 2200 VA
- UPS - external
- 23.3 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 10%
- Power Capacity
- 1980 Watt / 2200 VA
- Input Connectors
- 1 x power IEC 60320 C20 16A
- Output connectors
- 8 x power IEC 60320 C13 , 1 x power IEC 60320 C19
- Battery
- Lead Acid - 9 Ah
- Batteries Qty
- 4
- Run Time (Up To)
- 3 min at full load
- Networking
- RS-232, USB
- 17 cm x 43.2 cm x 22.1 cm
- Environmental Standards
- ENERGY STAR
- 3-year warranty
- UPS - external
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 160 - 283 V
- Input Voltage Range (Adjustable)
- AC 151 - 297 V
- Input Voltage Margin
- ± 3%
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 10%
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 405 Joules
- Quantity
- 4
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- Capacity
- 9 Ah
- Run Time (Up To)
- 3 min at full load , 12 min at half load
- Recharge Time
- 8 hours
- Remote Management Interface
- RS-232, USB
- 1 x management (USB) - 4 pin USB Type B , 1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x EPO (emergency power off)
- Cables Included
- EPO cable , Serial cable - external , USB cable - external , Power cable - external - 3 m
- Equipment Protection Value
- 100000 Euros
- Audible alarm, emergency power off, LCD display, Automatic Voltage Regulation (AVR), GreenPower UPS Technology, overload protection
- C-Tick, RoHS
- Software Included
- PowerPanel Business Edition
Sustainability Information
- ENERGY STAR
- Limited warranty - batteries - 3 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
- 17 cm
- 43.2 cm
- 22.1 cm
- 23.3 kg
