The Professional Rackmount PR1500ELCDRT2U UPS with LCD readout and pure sine wave output is Active PFC compatible, safeguarding mission-critical servers, telecom equipment, VoIP and internetworking hardware that requires seamless connection and advanced power protection. Featuring Automatic Voltage Regulation (AVR) technology that helps to stabilize AC voltage and to provide protection to connected equipment.This UPS system is designed with patented GreenPower UPS™ bypass circuitry that improves the operating efficiency so that users can enjoy significant cost savings by reducing energy consumption and waste heat generated.
The PR1500ELCDRT2U comes with a capacity of 1500VA/1000Watts and eight (8) IEC C13 receptacles, including two (2) for critical loads management. It has four (4) hot-swappable, user-replaceable 12V/7Ah batteries. The multifunction LCD panel with control switch allows users not only to easily check the real-time power/battery status at a single push-of-a-button, but to quickly configure settings within a few touches. RJ11/RJ45 (One-in/One-out) port is included for the protection of phone and network line. The EMI/RFI filters increase the tolerance of noises and load interferences so that improve the picture and sound quality in audio/video systems. The unit offers one (1) HID USB and one (1) Serial connectivity port with PC and one (1) Emergency Power Off (EPO) port for the capability to immediately power down entire installed equipment from a single access point.
The PR1500ELCDRT2U features remote network management capabilities which include the PowerPanel® Business Edition software, an optional SNMP/ HTTP remote management card, and an optional ENVIROSENSOR. These management tools enable administrators to perform various operations including remote management, real-time monitoring, UPS configuration, and scheduled server/workstations shutdowns. All Smart App UPS systems and Remote Management Card have achieved the status of Cisco EnergyWise certified, better supporting other EnergyWise-enabled entities and be easily monitored and controlled to achieve the best energy performance under the EnergyWise operation framework.
For as long as you own this product, CyberPower will cover up to $100,000 of properly connected equipment if it's ever damaged by a surge, including surges due to lightning strikes.
- CyberPower Professional Rack Mount LCD Series PR1500ELCDRT2U - UPS - 1 kW - 1500 VA
- UPS - rack-mountable
- Rack Size
- 2U
- 27 kg
- Output Voltage
- AC 230 V ± 5%
- Power Capacity
- 1 kW / 1500 VA
- Input Connectors
- 1 x power
- Output connectors
- 8 x power
- Battery
- Lead Acid - 7 Ah
- Batteries Qty
- 4
- Networking
- RS-232, USB
- 43.3 cm x 38.8 cm x 8.8 cm
- Height (Rack Units)
- 2U
- Input Voltage Range
- AC 160 - 290 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- 1 x power
- Power Output Connectors Details
- 8 x power
- Output Voltage
- AC 230 V ± 5% - 50/60 Hz
- Power Capacity
- 1 kW / 1500 VA
- Dataline Surge Protection
- Network/phone line - RJ-45/RJ-11
- Output Waveform
- Sinewave
- Surge Suppression
- Circuit Protection
- Circuit breaker
- Quantity
- 4
- Technology
- Lead Acid
- Capacity
- 7 Ah
- Recharge Time
- 8 hours
- Remote Management Interface
- RS-232, USB
- 2 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type B , 1 x management (USB) - RJ-11
- Expansion Slots
- 1 (total) / 1 (free) x Expansion Slot
- Cables Included
- USB cable - external , Serial cable - external , 4 x power cable - external , Phone cable - external
- Rack Mounting Kit
- Included
- Audible alarm, LCD display, Automatic Voltage Regulation (AVR), GreenPower UPS Technology, overload protection
- Software Included
- PowerPanel Business Edition
- 43.3 cm
- 38.8 cm
- 8.8 cm
- 27 kg
